Old January 29th 2010, 06:05
Originally Posted by dub_crazee View Post
anyways more pics! Ally spacer blocks for the beetle mounts
Carefull with those protruding bolt heads in your tranny bellhousing. They _may_ just hit the flywheel ring gear...
Old January 31st 2010, 06:22
dub_crazee's Avatar
thanks for the heads up wally. i will be using countersink bolts though as i said
yesterday my gearbox blocks to mount on the beetle cradle turned up and they work nicely i just need to get some countersink bolts but this is it mocked up.
this week i made several purchases that i probably shouldnt have as i'm fairly skint at the moment lol! my CSP wings turned up along with my order from pelican parts so i can now build up my rear arms. i also won a pair of 2.0l cylinder heads on ebay very cheap, and some 96mm barrells and pistons.
also this week i changed the door pins on my passenger door, prepped both doors and rear valance and got a coat of reface on them so im pretty pleased
Classic Car Revivals
www.classiccarrevivals.com
Old January 31st 2010, 08:56
Oeps, must have read over that part...
Well, better safe than sorry
Old February 7th 2010, 13:48
dub_crazee's Avatar
ive dont a bit more on my bug - but mostly filler work which is dull as fcuk! and messy....but gota be done....especially as i want to to be as stright as an arrow!
both doors and rear valance are now in reface
and the passenger door has new door pins
i noticed my origional door has an audi logo on it - shows how late it is :lol:
decklid received the swiss cheese treatment also and is now ready for reface
quick pic of the barrles and pistons....anyone have experience of the aa stuff? is it any good?
also turned out the 2 litre heads i won on ebay were 1.8 heads.....which is nice!
Old February 7th 2010, 13:50
dub_crazee's Avatar
also had the boxster S rear discs opened up to sit on the 944 hubs
discs have gone off for powdercoating.
also rebuilt the a arms with new bearings etc and put together the spring plates with weltmeister bushes
slowly but surely making some progress
Old February 7th 2010, 17:25
MX67 MX67 is offline
how bout those Boxster discs at the rear. What it means "opened up".
You mean inside, so You can fit them on to the hub?
Cool project by the way 8)
1967 Bug
Old February 7th 2010, 17:33
dub_crazee's Avatar
yeah the hole in the middle has been enlarged 2mm iirc - to the same size as the 944 disc so it sits on the hub in the correct position (if you look closely at the hub there is a raised ring)
Old February 7th 2010, 17:35
Cool.
Does OG 944 4-pot caliper fits perfectly, or You've made some spacers, or You don't use them at all?
1967 Bug
Old February 7th 2010, 17:38
dub_crazee's Avatar
il be running 996 rear calipers (same as boxster S) but the disc is the same diameter and thickness as the 944 turbo disc - however i think the offset is slightly different but again only a couple of mm so may require spacers for 944 tubro calipers
Old March 13th 2010, 12:45
dub_crazee's Avatar
well ive been working on the chassis this week to get it finished. ive shamelessly copied a couple of ideas off of another project build on here but as it ws one of the neatest installs ive seen it seemed silly not to!
The rear mounts worked a treat but needed 8mm spacers between the framehorn and cradle
and this is the front mount welded together
which was then trimmed and neatened up
the shift rod was shortened 20mm
and the underside of the chassis was closed up similarly to the other project build.
Framehorns were clearenced for the Larger CV joints
and kafer bar set up mocked up and the tabs welded in
i only had 1 short and 1 long bar to do this as the rest is still being made
i also ran the fuel lines
its off to the blasters and powdercoaters next week, then the obttom is being gravitex'd and painted black (over the powdercoat) then i can start to think about building it up!
Old March 13th 2010, 19:17
chug_A_bug's Avatar
really nice work man...
keep it up love the welds and fab work Super Clean
keep the pics coming
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old March 13th 2010, 23:27
Nice MIG welds! Love the install so far...keep it up! This forum is for helping everyone with their projects.
Old March 14th 2010, 04:00
dub_crazee's Avatar
Thanks for the comments guys
wrenchnride i dont think it would have been quite the same if i hadnt seen yours :lol: you've definately helped me!!
i'm already thinking about going over to the porsche coupling instead of the beetle coupling lol!
i wont be doing any work on it for a few weeks now as im moving house and changing jobs in the same week.....but when the chassis comes back il build it up and get it rolling - the body is booked in for paint in 10 weeks and i rekon ive got a couple of days tieing up lose ends on that before shes ready to go!
thanks again
Deano
Old May 19th 2010, 17:13
dub_crazee's Avatar
Well with starting a new job and moving house theres not been any progress to speak of over the last couple of months, but today work started again, heres a sneeky peek of the rear end....
ive got my motivation back
im going to dry build the car before paint - and ive got some mods to make so the paint date has been moved back a bit!
Old May 19th 2010, 17:33
Cheeky shot, nice rear end you have there!
