After tossing a couple of ideas around on were to mount my new shift light. I cut a plate to fit between the steering wheel and hub, drilled it up, painted it and mounted the shift light. I had to buy a 3 wire spiral cord and 3 pin connector so I can turn the wheel and allow the cord to stretch. I still need to wire it all in.
![]() I got most of the engine bay wiring done. Still need to rewire the tag light and run a new pick to the third brake light. I cleaned up all the old wiring and ran everything thru heat shrink tubing, then wrapped it in nylon spywrap were it needed extra protection. ![]() Still need to wire in the shift light, 2 relays for fuel pump and Mallory 6AL and wire the 6AL. I might need to wire in a Tach adapter if it does not work with the new CDI box. My list is getting shorter. Only 3/4 of a legal pad page.
Thread Tools | |
Display Modes | |
