Old January 19th 2014, 09:25
Another day of pipe wrestling ;D
On the background a few errors.
Paul.
Old January 20th 2014, 17:33
cookvw's Avatar
cookvw cookvw is offline
A better pic of where both ends of the tube that supports the top of the Coilover of where they tie in at would be awesome.
Old January 22nd 2014, 16:19
I am sorry this was the best pic I had.
The gearbox has a special mount (bellhouse side). from this mount there are tubes going to the top of the main hoop. the torsiontube is narrowd therefore the body mounting point is on the inside of the innerwing (nrmally on the outside). I made the second tube from this body mounting point to the first tube (this makes a triangle). The schok is mounted to the tube that is going from the body mounting point to the first tube. Stil with me?
Old January 22nd 2014, 17:06
Starting to look like a real cage.
Paul.
Old January 22nd 2014, 17:15
Cool! That will deffinately be 'Spa-froncorchamp approved' :-)
Old January 23rd 2014, 15:57
Thanks.
I am following the drag race rules (rules received from Rojo Racing) as good as possible.
Old January 25th 2014, 16:23
Another pipe added.
Paul.
Old January 29th 2014, 09:03
new pipe update.
Paul.
Old January 30th 2014, 11:46
Rule09 Rule09 is offline
Everything looks very good!
Old March 15th 2014, 14:42
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Nice! I am getting close to the cage stage of my build so you help inspire me.
Old March 16th 2014, 15:38
Thanks,
Old March 19th 2014, 16:09
Bended the 2nd pipe. just a little fitting and it is ready. one pipe to go before the welding can start.
Paul.
Old March 19th 2014, 16:12
Can you get the fuel tank out OK, looks close! The bends look good, what sort of bender are you using?
Rich
Old March 19th 2014, 17:09
Rich
Hi Rich,
Not sure about the tank yet. First I have to shorten the right tube a bit and tack-weld them.
The bender is just a simple hand (hydraulic) pump.
Paul.
Old March 26th 2014, 16:03
Can you get the fuel tank out OK?
Rich
Now I can
Paul
