Well, time for an update seeing as I have 2 weeks off for the Holidays and need to make a big push to have this bug on the road for spring 2011.
Dash before: (needed to install a kickin stereo in high school )![]() Tried to cover it up and make it look acceptable ![]() 2 days of cutting / fitting / welding ... thanks for the donor dash Pete ! ![]() Cleaning up the "interior oil cooler experiment" as I now have an RX7 oil cooler up front
Re did the fuel system up front thanks to comments from the group ...
![]() ![]() -8 line from the fuel tank to Aeromotive canister filter (100 micron), and then -8 to the swirl tank, -8 feed to the Bosch 044 fuel pump. Still need to run a -6 line from pump to regulator in the back, and then a -6 return line to swirl pot. ![]() Front end complete except for plumbing up the brake / clutch hydraulics. The lines have been run, just need to terminate the fittings. Lanner is working on the new splindles, current ones are temporary so I can move the chassis around. |
Need to spend a few days fixing the rust in the rear area before I can place the body on the pan, and work on the heater channels.
![]() ![]() Dash display coming along nicely. ![]() ![]() I have all of the parts to put the long block together, then need to build a horizontal cooling system .... NEED TO GET THIS ON THE ROAD FOR SPRING 2011 !!! ![]() Thats it for now, more progress as it happens. Sandeep |
Looks great, I especially like the display.
Can't wait to see it (and maybe get a ride in it) Bry
GL ghia restoration: http://s473.photobucket.com/albums/r...20restoration/ __________________________________________ |
I like all the control boxes!
The screen now reads s/th like 'Read the f*cking manual'!!
