Old January 18th 2011, 19:31
I had the same issue with my 1303 daily driver/sons car, it has steel 944 arms and the very end of the spring plate touches the trailing arm, its only slightly toeing out and only showed up at the alignment shop, Im going to take a bit of the end of the spring plate to correct this.
On my other 1303 which is using 1986 alloy arms the toe out is very noticeable to the naked eye, moving the trailing arms any more forward could cause the wheel to be too far forward in the arch.
Good idea wrenchnride I will try moving the washers to the inside.
