Old November 11th 2010, 02:53
Your doing excellent work, I'm taking the body off a 1303 soon so it can be painted, I'm glad that we don't have the same problems down here as you do there.
I might be seeing things but in the photo http://www.keversite.nl/fotoalbum/fotos/99903.jpg it looks like there is some sort bulge on the chassis floor at the rear end behind the seat rails, is this for something special or is it a piece of your bug puzzle waiting to be fitted?
Old November 11th 2010, 05:04
Thanks Steve,
The bulge is made to fit the oilcooler, I think this will have plenty of airflow. Good luck with your car.
Paul.
Old November 11th 2010, 06:04
Nice work Paul! I don´t think I have ever seen anyone make such a big modification for an oil cooler! I like it!
Old November 11th 2010, 07:01
MX67 MX67 is offline
This looks nice. No rear legroom, but who care!
1967 Bug
Old November 11th 2010, 07:05
No rear seat, so who cares
Old November 11th 2010, 09:02
Wow I never would have thought of doing that.
Old November 11th 2010, 12:51
T5WOB's Avatar
T5WOB T5WOB is offline
nice work well done
kerb$ide ku$toms
Old December 13th 2010, 00:53
KAFUR1's Avatar
KAFUR1 KAFUR1 is offline
Slick I like! Hmmmm
Old January 12th 2011, 16:20
Found some time to work on the car again 8)
The underside of the left doorpillar was bad, of course >
time for a Hoekie of Hooky
First I had to shorten it, this way the bracing could stay in it's place.
fitting
It only needs some welding. 8)
Paul.
Old January 15th 2011, 15:37
This morning it was time to finish the doorpillar.
Welded the hooky piece.
Normally you can not reach the inside, mine is still open and it is double sheetmetal so I also welded the inside.
Then I dismantled the door (this is very heavy with all the parts and glass in it) and checked the gap, I must say ; I am very pleased with it.
Paul.
Old January 21st 2011, 03:36
ido vw ido vw is offline
Awesome work Paul! keep update!!
Old February 1st 2011, 12:28
Thanks, I am ill wright now but next week it is time to do some work again.
Paul.
Old February 17th 2011, 15:33
Not much time lately, but still a Little progress.
This piece of the trunk was a little thin, also the holes didn't mach the new kick panel. so I replaced the top of the kick panel by a wider piece, this way I can close (weld) all the holes.
And all the holes are closed again. before paint I will put some lead filler on it and it will be as new again, offcourse I will do the corners first.
Paul.
Old February 18th 2011, 13:15
Bad bug's Avatar
Bad bug Bad bug is offline
Paul where did you get the lower door post panel to buy.
Old February 18th 2011, 15:16
Do you mean that green piece? It's a hooky piece, perfect fit.
http://www.hookyspanelshop.com
Paul.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
