Old August 19th 2011, 03:33
-Alex- -Alex- is offline
I'v done cad modeling about the cylinders and heads. You can have JPM heads with wbx stud pattern and desired bore. STD opening on JPM wbx stud pattern heads is 111,1mm
This is cylinder has 98mm bore and 4mm thickness. Head does look quite thin when 111,1mm opening, but thinking if leaving it smaller and using max 100mm bore..
BTW, i found cheap shipping for mendeola a-arm kit, box is 122x96x60cm and weighs 71kg, only 120 euros at boat from LA to Finland
