Had a pretty productive night in the garage. Second night in a row that I've gone in at about 5pm, found myself really hungry only to look up and realize it was now midnight!
Started off by grinding away all that POR15 I had laid on the pan (sigh). From there I welded on the mounts for my front transmission mount. ![]() ![]() They allow me to use the urethane transmission mounts, or factory beetle transmission mounts, to secure the front end of the transmission to the pan. And with that sorted out I moved onto closing up the gaping holes in my floor pan. Originally I was going to use a CV joint boot as a seal, but that turned out to be too large. I figured a boot from a power-steering rack would be perfect, but turns out I don't have any kicking around anymore. In one of my bins, though, I did find a brand new set of balljoint boots. It's a perfect fit, but will be a PAIN in the butt to deal with at a later date if I use the wire clips. The wire clips will ensure a full seal though. Hmmmmm... ![]() Behind the boot, holding it on to the sheet metal, is a .5" section of 1.25" exhaust tubing. Just enough to hold the boot on. The boot is pretty stiff, so I may only use a wire clip on the pan side and let the shaft slide in and out of the boot. Tomorrow I will seal up the torsion bar housing, and then tear it all back down to paint it. I have a couple of items to finish on the actual transmission, then I can finally flip the pan over and sort out all the other issues. I still need to move the accelerator cable and clutch tubing coming out of the pan, solve the clutch release arm hitting the frame horn, finish modifying/sealing the speedometer gear and then I can move onto rear suspension. ![]() -Dave
Thread Tools | |
Display Modes | |
