Go Back   GermanLook Forums > General > Members Rides
Old January 12th 2012, 15:31
Hi Kai,
Saco kit worked very well for me. I had the gen.1 version (obviously) and just replaced the nylon line from slave to master with a (copper) brake line. I was afraid the brake line would be too small in diameter, but it works fine still. If you have the choice, I would use a slightly bigger line.
Even with the original slave (from CNC), it worked just normal, not especially heavy, even though the stock 915 clutch operates very heavy in itself.
I still run the original master from SACO, but now with a annular VW (Passat) slave. Still works fine (against my expectation lol).
Good luck,
Walter
