Old January 31st 2012, 16:08
Bleeding an all new brake system can be a real pain. If the rears are not bleeding right. Try jacking the rear of the car up as high as you can and then bleed them. If you have a high place in the line running to the rear. Air will collect there and it can be hard to get it to move from that spot. I have had to jack one end of the car, use a mighty vac on the bleeder and put pressure on the fluid res. and pump the pedal, just to get all the air to move out of a high spot in the plumbing.
