Old March 31st 2013, 16:57
Bruce. Bruce. is offline
Originally Posted by Bugged View Post
I rebuilt my Super Beetle steering box today.
I still can't remove all the play from the box. The tolerances seem to get tighter when the steering is dead center. So when the pitman arm is all the way left or right, there is play, but as you approach center, the play disappears. I inspected the worm gear and roller and they seemed in pretty good condition. .
The 356 experts say to set up the steering box and steering arms so that the box is precisely centred at straight ahead as there is minimal play at that point. As you move away from dead ahead the play is more but less important.
Old April 1st 2013, 22:12
Humble's Avatar
Humble Humble is offline
Important note on gauges: if you are going fuel injected and have an ecu with a serial or can output, you might want to consider a digital dash instead. I spent ove $1200 in autometer electric gauges and senders, as well as a dual cyl. head temp gauge. I could have saved $350 or so and gone with a programable dash from racetechnologies, or racepak.
I'll be ditching my autometer gauges in the race bug and going with a programmable dash for the new motor.
fwiw, here's the gauges I run
5" tach, 5" speedo, 2 5/8" fuel, ego (wideband), boost 30 psi, oil temp, oil pressure, and dual cht on #2 and #3
Old April 1st 2013, 22:22
Bugged Bugged is offline
So I am currently not going Fuel injected, but it is a long term goal. (Turbo FI) I'm assuming that the programmable dashes are not compatible without an ECU.
Old April 1st 2013, 22:49
Humble's Avatar
It depends on the dash, some can use external sensors, and some only poll the ecu over serial/can bus. Typically, logging capable dashes will take external sensors, or have an additional box that does. Either way, a logger is nice to have regardless of setup, but usually adds 50% to the cost.
Old April 2nd 2013, 04:13
I am running a DTM shroud and have a CHT gauge for #1 and #3.
Old April 2nd 2013, 13:30
Sense will out, but i see the weight saving advantage, high weight too, so a handling plus.
Old April 2nd 2013, 16:53
Originally Posted by spannermanager View Post
sense will out, but i see the weight saving advantage, high weight too, so a handling plus.
huh?
Old April 2nd 2013, 16:55
I am pretty sure I will get these seats, Sparco Sprint 5. They are narrow enough to fit in the bug without looking awkward in my opinion. FIA approved and have the submarine hole for the 5th belt.
What is your opinion. 4 or 5 point seat belts? Any sanctioned race will require 5 point, but is it overkill for me? I will be doing track days, but doubt I will be doing full fledged races. That being said, the safer the better. My worry is if they will be a pain to put on and off, but I have heard 4 point are more of a PITA than 5.
Old April 2nd 2013, 23:53
Bug@5speed(US)'s Avatar
For any track event 5 or 6 point best. Antisubmarine very important feature that 4 point can't provide.
Not that inconvenient to take on and off with practice.
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old April 3rd 2013, 02:42
I feel like I'm turning this build into a random questionaire... haha. Anyway, I am looking to install a push start ignition in the car. I think I understand how to wire one up with a relay, but I found this diagram.
Doesn't the Engine Start button side of the relay need a low current power supply in order to actuate the relay when the momentary switch (start button) is closed? Once the relay closes, then the circuit to the "starter wire" (which would be to the + side of the coil), would close and actuate the starter?
Old April 4th 2013, 11:29
huh?
An array of analogue gauges and old type wiring is heavy and high as in C/G?
Digi dashes way naff all and can be low mounted if required, and thin wall wiring is very lightweight.
Old April 4th 2013, 11:37
This ^^^^^ and another weight saving opportunity here also with an ultralight pro harness, these and the digi dash and thin wall wiring can save well over 3 kg. the budget steel harness fittings start to nag on you if your in the car for an hour or more, i seem to remember posting one that weighed in at 3.5 kg
Old April 4th 2013, 13:38
Humble's Avatar
Actually, one of the biggest arguments for a digital dash is not weight but information. You layout different "pages" on the dash and each one can report different info. It also saves time looking around at a dozen gauges for 15 seconds while you're on a straight.
As for belts, Alex is right, you want at least a 5-point, and preferably a cam lock. If you've ever put on a 4-point belt and cinched it up wrong, it'll creep up your stomach. Submarining under the belt is the same thing but happens much faster during an accident and the 5th point prevents that. I've also had to spend, probably hours now, explaining to passengers how a latch link belt works and how to put one on. It's worth the extra money for a cam lock to never go through that, coincidentally, I'm also switching to cam locks
As a rule of thumb, you can never be too safe. Consider this, a $600 seat, $300 belt, $900 fire suppression system, $800 fuel cell, $1200 roll cage, $1500 fire suit, $400 helmet, etc., seem like big purchases up front, but they can prevent tens or hundreds of thousands of dollars in hospital bills after an accident. So when you look at safety items, your foremost question should be, "How much am I worth?"
For the relay, most automotive relays will take 12v for the coil circuit. so the starter relay would look like this
T85: ground
T86: +12v from start button
T87: to starter
T30: +12v in
This is for 4 terminal relays, if there is a fifth one (87a), don't use it. Terminal 87a is a passthrough power until relay is activated then 87a goes to 0v and 87 goes to 12v.
Old April 5th 2013, 01:22
owdlvr's Avatar
owdlvr owdlvr is offline
So here's my thoughts on your questions...
Sparco Sprint - Sparco Sprint seats are a made with a steel tube-frame construction. While FIA certified, and safer then a non-certified seat, you should consider the use of the vehicle before buying them. If there is a significant chance of serious accident in the car (track racing, stage rally, etc.) then I would pass on the Sprints and find a composite construction seat. You want to avoid a situation where the seat frame could distort or break and injure it's occupant. In the case of rally-cross or autocross (where accidents which damage the passenger compartment are far less likely) a Sprint would be a fine choice.
4pt belts - Avoid these like plague. As already stated, it's pretty challenging to do these up properly without the buckle rising up into your abdomen. An accident (even minor) could cause you great internal damage. Go with 5pts or 6pts, and always run the submarine belt...even to the corner store.
Push Button Start - I would encourage you to consider why you want a push button start with the ignition key still in use. Keeping the stock ignition cylinder intact simplifies the wiring, and keeps the theft protection functional. Adding a push-button in addition to the key adds three additional points of failure (button, relay and wiring) any of which could disable your car mid-competition. I would suggest you either a) ditch the ignition switch entirely (I can give you wiring diagram) or b) forget the push button.
Digital Dash - Not really a question, but I figured I should jump in on the conversation. The biggest advantage to a programmable dash is that you program the display to only show information if there is a problem. It could show oil temp until it reaches operating temperature (for instance) and then never show oil temperature again unless it gets too high...then it should flash or otherwise attract the driver's attention. If someone is using traditional gauges, simply twist each gauge so "normal" operating condition is with the needle straight up and down. Your brain no longer needs to "read" gauges. You simply glance over for a millisecond and look back forward. Your brain processes whether or not all needles were "straight up", and only if they weren't do you need to take the time/brain power to look and read the problem gauge.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old April 6th 2013, 12:30
Bogara_ZO's Avatar
Sorry for hijacking, but can you tell me please where the submarine belt should be attached (what is the best angle?)? Slots in the seat are required in this case?
