#91
jmd, I'm after few things really.
1. I'm looking for more adjustability out of the back end than I'm getting from the stock porche spring plates. It's also a pain to fine tune with the eccentric adjustment bolts. 2. I want to cut down on the rear end slop now that I'm playing with the much higher cornering loads that slicks produce. These plates and delrin pivot bushings should help with that. 3. I like giving back to the community where I can and getting suspension parts from members puts money into GLer hands. If you aren't making a time attack car the stock parts are great. Even for intermediate track use on street tires they will hold up just fine. I'm at the stage now where I'm trying to go from the top 8% to the top 5% and I need reliability and repeatability.
#92
I am now offering bus kits also
#93
Thought I'd put an update here and put up Alex's hard work. I finally had a chance to open the box and check out the parts. They are very robust and absolutely beautiful!
#94
Have any pics of where and how these swaybars mount?
'72 super '65 bus '52 split |
#95
Here's a pic I took earlier, I can try and grab a better one from the backside later.
#96
Cool, thanks
#97
Humble what size bar u running in the back.
I was going to use some 944 but with the Gwd rear sway bar mounts and our 901 front traverse it is not a good fit. The 944 seem shorter then the beetle ones by an inch or so. If I have to use the 944 I need custom endlinks at about 5 inches or so. Thinking the beetle may be a better fit but can I trouble u to measure the short length so I can compare. Rear IRS conversion bits look really nice need to check the price. A
#98
CNC made aluminum Uniball rear suspension system
Ordered my uniball set up from Alex
![]() ![]() , slowly getting all the parts together now.
gee dub |
#99
These came out nicely, two setups are ready to go, Beetle with 944 aluarms and Bus T2 with steel arms.
#100
At the moment, until end of the february, i can sell 1-2 sets for 700€
#101
Alex - is that price for your Beetle to 944 alu arms? With all the hardware? If so, let's talk about me getting one of those sets.
thanks. jmd |
#102
Same price applies to aluarms and steel arms.
#103
One set being made for JMD
#104
I want to tell folks that might be considering this.... Alex has be absolutely fantastic to work with - his communication has been top notch and he has been great to do business with.
if you are nervous at all - don't be, just pull the trigger and get you some of these sexy ass parts! Thanks Alex! jmd |
#105
I can still offer one or two sets less than 800€ before May, but at price 750€, due to a risen cost of aluminum and actual machining time.
As for timetable, usually i'll get the aluminum in 1,5-2 weeks, machining takes time 2-3 weeks. Bolts and uniball joints i'll get at few days. Last edited by -Alex-; March 24th 2014 at 03:19. |
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
