Old May 16th 2014, 15:38
I love all the hard lines, I wonder if you've considered vibration and fatigue cracking over time?
Hi Jason,
Yes I thought about that. Inside the chassis are a few steel tubes welded to the side. All the fuel lines are mounted with tyraps to that tubes. I mounted a little rubber hose around the tubes to make sure the lines don't rub.
Paul.
