Old September 19th 2014, 23:22
effvee effvee is offline
Automatic transmission
Hi everyone, I have a seized up 915 trans, I also have a I believe the seller said, it was from a 912 trans. I have pieces that I want to build a posi four speed Quaife trans. And lastly there is the three speed type III automatic transmission.
At the time, I was conversating by email with a builder in Australia, his thing was type III VW automatic.
Since I want the engine to be turbo, there is no vacuum signal for first/second shift point. I removed the vacuum modulator, and had a fitting made. The fitting enabled the attachment of a mechanical modulator.
Lastly I have read that the type three auto diff and housing can be morphed together with a Audi 5000 torbo trans, in doing so, would make for a strong automatic, you input would be appreciated
Old September 21st 2014, 08:40
Aaron the auto guy in Australia has nearly finished his drag notch, Im sure he will have lot more data when its running. We are both running a VW drag event in a few weeks time, he's really trying to have his notch finished for that.
Old September 22nd 2014, 01:18
Good evening, I'm all over the place with this transmission subject. I have the time, presently, I'm trying to envision my third and keeper 1303.
I'm not sure if it will have a EZ 30, or the three liter type IV twin turbo. My car, I want it to be a SoCali freeway flyer. Yes a definite GS, but simply a bad a$$ street car.
This type II automatic I have read is very strong, it can take the abuse. My need is for low rpms,speeds up to 90 mph. Quaife sells a ATB unit for the type II automatic. I did start on trying to adapt it for mechanical modulation. I was trying to learn which parts can be borrowed from other trans applications. I don't want to make money on this, just build myself a strong trans.
I still have issues on how builders are relocating the frame horns. This is one of the reasons I won't get the G-50, I've seen builders having to heavily mod their axle tube. I'll need to revisit Walter's G-50 tread.
If you could share some inside on the type II auto build it would help.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
