#181
STI powered 1303 in the works. Last edited by Steve C; December 19th 2017 at 05:45. |
#182
Very nice! Did you experiment with and without rear wing (pics show both, hence)?
#183
Hi Wally
I tried it with and without, couldn't feel any difference, I think the wing would help when corners are involved. Steve
#184
A more professional video of the Snowy 1000 http://youtu.be/m7TLBbAH-Pg?list=UUY...0MUhzgstStiyVQ Steve
#185
Another piece of my quest for more power arrived today, its a sensor to tell my ECU the percentage of ethanol in my fuel, I can then run my car on the street on regular 98 RON fuel and then when I'm competing in an event I can fill the car with E85. When my new cams arrive next year I will be getting the motor retuned a bit more aggressively on E85 fuel Steve
STI powered 1303 in the works. Last edited by Steve C; December 19th 2017 at 05:46. |
#186
Great pics and I love the E85 sensor plans!
#187
Thanks, E85 = more timing & boost = more power
#188
Love your car and the videos btw! Cheers, Mark |
#189
Thanks, I like the work your doing on your car I'm going to put it in the return line as close as I can to the motor, low pressure less dangerous. I think all the sensors are GM just re stickered. When I get it tuned it will be on 98 RON and then blends from straight 98 to straight E85 and then mixtures of both. Its an expensive tune but the results should prove worthwhile, just waiting on the Tomei pon cams now. Steve
#190
Thanks! I was thinking the same about the pressure, but figured it would be more logical knowing what the ratio is before it enters the engine? However,come to think about it I guess that would only be an issue during cranking for start up. Expensive is right, I checked the price on the Zeitronix stuff. I bought a Siemens/Continental Flex Fuel sensor new for $70 US dollars,which is what GM uses also.I have an MS3 ECU from Autotune.fi. All I had to do is add a jumper wire. It was this simple mod that convinced me to go flex fuel. I am eager to see how well it works.
#191
I'm running a Autronic SM4, it needs the Zeitronix gauge to send the correct signal to the ECU. My sons building a new drift car, a Nissan Ceffiro with an RB30 turbo motor, hes going flex fuel as well but using a locally made ECU by Adaptronic, the sensor just plugs right in like your setup. Steve
#192
i just googled the Autronic SM4...wow amazing ecu you got. how do you like it so far?
#193
I'm pretty happy with the SM4 so far but as its an older ECU so it doesn't have plugin flex fuel even though I will be fitting the latest chip and software to it. It is a plug n play ECU so it uses all the stock harness and sensors My son is using this ECU http://www.adaptronic.com.au/product/e1280s/ in his new drift car, its pretty amazing what it can do for the price. My son is also using this dash as well http://www.adaptronic.com.au/product/rt-dash-2-display/ Steve
#194
1st part of the quest for more kiloWatts was fitted today, but not without dramas. I've mounted the Zeitronix Ethanol Content Analyser (ECA) gauge to blind spot in the dash, right behind the steering wheel, I made a bracket to bolt it to the fascia that the tacho/speedo sits in, only problem was that when I connected the tacho back up again ECA wouldn't work, after much head scratching I finally worked out that the tacho earth was feeding into the ECA housing, some ECAs I've seen are just mounted in the glove box, but I had a spare space so I thought I would use it. Interesting the BP 98 I normally use has 2% ethanol content. I can also see fuel temperature by pushing a moment switch on the ECA mounting bracket, but what you can use this reading for is a mystery. The ECA has two outputs that are sent in a 0-5 volt signal to my ECU so that it can alter fuel and ignition maps to suit the ethanol content of my fuel. Steve ![]()
STI powered 1303 in the works. Last edited by Steve C; December 19th 2017 at 05:48. |
#195
I really need that rear wing decklid to hide my STi intercooler build. The link for them is dead. Anyone over there still building them?
Thanks Randy
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
