#1426
Well, since the rods aren't still here yet, I'll thought to start om making the yellow calipers work.
It didn't.. the bolt spacing is bigger (142mm as opposed to the regular 130mm). So, I started thinking of other solutions. I kinda strayed towards using the original 996GT3 bearing carriers so the whole thing would fit. That just means adapting all other 3 fixation points: (shocks, tie rod and lower control arm). Here was a test fit with a rear 996/986 wheel bearing carrier (front and rear are basically the same casting):
#1427
Hi, question, ars you going to use struts? I see the spindle hole is splined, is that one is for the rear correct? Your rods, have you ever heard of Gregg Cunningham? He made my rods.
#1428
Yes, with (GT3 RS) struts from Sachs racing, also height adjustable and even with external reservoir. The spindle in the picture is indeed a rear (test dummy) spindle, even the wrong side spindle. Its just to get an idea
![]() Heard of Cunningham, but thats it. Mine will be from Pauter. |
#1429
#1430
Wally--
I like the look of those arms, though having the Porsche moniker would immediately make them too expensive for me, most likely. I have always believed the LCAs and their inner mounts are the weak point of the 1302/03 front suspension. The mount hangs down a bit, ripe to be smacked into oblivion during an unfortunate off. I think one could create a more stout inner attachment meant for those Porsche rear arms that would accommodate the shorter length. The only immediate issue I see is the lack of mounting for the sway bar, or, better yet, a trailing arm to isolate the sway bar. If you were to create a mount to use those arms, how would to attach the sway bar?
johnL (aka H2OSB) '74 1303, Outlaw sedan (with a GL flavor) |
#1431
Actually although many have deemed the original LCA's a weak point, I think the construction is pretty solid and a nice combination of a wishbone kind of way combining the sway bar into the suspension set-up. There is indeed no way to use the pictured porsche parts due to lack of sway bar attachment. Sooo, I have come upon a small company in germany that makes an aluminium LCA for the late 1303 out of 7075 aluminium. However, his small batch was already sold out. Next weekend I am able to see one of those sets on a new years VW event in germany (Herford). Of course, I'll try to make a picture of said arms. Here's the set on Mario Asstmann's reincarnation of a GSR: ![]() and the rest of his car on FB: https://www.facebook.com/pg/gelb.sch...=page_internal Last edited by Wally; December 22nd 2017 at 05:58. |
#1432
I like the look of those. Is that something still available? Are they super (no pun intended) expensive? Oh I saw the link. I will go look.
There is no doubt the original forged arms are plenty strong, but the stamped welded later arms are a weak point. You can stand on them and make them flex. Doesn't mean I won't get them sandblasted, prime then paint with black epoxy paint and use them...I'm just sayin. H2OSB
johnL (aka H2OSB) '74 1303, Outlaw sedan (with a GL flavor) Last edited by H2OSB; January 10th 2017 at 17:39. |
#1433
![]() ![]() Well, what can I say...I went to the german new years meet in Herford and the builder of those arms had 1 set reserved for someone that didn't wanted them after all. Soooo happy with them! Yes they are super expensive. They are also a a tiny bit longer then stock and are still 20% lighter then stock and a fair bit stronger: the material used is some sort of 7075 with a 10.9 comparable strongness. Its difficult to drill he said LOL! Last edited by Wally; January 14th 2017 at 14:31. |
#1434
Found the right spark plugs for the heads
#1435
Those arms are beautiful! Will they fit the 944 spindles?
#1436
They are Even more IRL.
Yeah, the outer diameter of the 17mm 944 joints are the same as the 15mm 1303 ones after all right? However, I want to try and install 996GT3 spindles and the accompanying ball jounts... That will be a challenge, especially as an american bank is holding my funds hostage I paid for the spindles... |
#1437
Why not just modify the chassis to take the 911 arms?
http://www.ricola.co.uk |
#1438
You think you have all the answers, don't you
![]() Ricola, you're probably right, but those sure are pretty. Wally, how much do those arms cost (ball park). Being slightly longer than stock, they might just solve my camber issue (n/a 944 spindles). Otherwise I'm going to mod the spindles strut flange to match the dimensions of the 1303 negative roll radius spindles. Also, can you link the source? I did look at the guy's build page but I didn't see a link for those arms. H2OSB
#1439
Don't ask what they cost, pls just don't
![]() They are mentioned on his site under 'alu querlenker' but without any details as they are 'sold out' (I got the last set remember )http://bugvision.de/besonderheiten.html There is an email adres on his site if you really want to know
#1440
He says he is out. I tried...
| Currently Active Users Viewing This Thread: 20 (0 members and 20 guests) | |
