#391
Master brakecylinders and clutch cylinder are overhauled and mounted with the TILTON pedalbox.
The Steering column is mounted and connected to the R&P and it works like a dream.. ![]() ![]() ![]()
#392
"tight fit"
#393
Nice taste
#394
Love it.
Excellent. |
#395
It's bin a while but I'm still on it.
After setting the stance I found out that the front shocks where too short. the new shocks are gas filled and a bit longer. ![]() I want the camber on the frontwheels somewhere between 0 and -1deg. but the adjustment did not go further as -2deg. now I will modify the Porsche A-arms. I will narrow them a bit and replace the original balljoint with an adjustable uniball.
#396
How is the build going?
#397
It is going very slow, I am renovating my house.
#398
Sorry, het staat vanwege de verbouwing van mijn huis op een laag pitje. maar wel wat gedaan.
Porsche draagarm uit elkaar gehaald ![]() Nieuwe draagarmen maken voor betere afstelmogelijkheden, lager kunnen en smaller. ![]() ![]() ![]() ![]() ![]() Centreerringen laten maken ![]() Fits like a glove
#399
slow progress.
![]() home again ![]() new spare wheel. ![]() made new a-arms with camber adjustment. ![]() New (test) tyres ![]() The test tyres fir perfectly.
#400
I like!
Nice garage floor BTW
#401
Due to small other projects, the bug was waiting in the corner. now it is time to start again/
Restored and sold a Vespa ![]() Fixed and sold a Honda ![]() Fixed and sold a 944
#402
Still not happy with the rearwheel alignment. time to order some monoball bushes and fix the problem. I always thought the driveshafts where a bit to long. today I checked and they are indeed to long, have to fix that too.
#403
Good to read an update!
#404
If some is good and more is better, then too much should be just about right! Last edited by fahrvergnugen; November 12th 2020 at 14:55. |
| Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
