Old August 25th 2019, 07:16
Simon Simon is offline
Not much to update on/share this week. Did do a bunch of work, but not very interesting.
Disassembled the whole rear and front suspension and chased the threads of all the bolts + the fender bolts and sent off the spring plates + all the mounting hardware to get sandblasted + zinc coated.
GWD Performance spring plate cover is on it's way, should be here the coming week.
Still in talks with Bilstein about the rear dampers, I think I'll use regular/custom threaded motorsport dampers instead of the 944 Cup ones and use something like the racer's edge bolts to space them away from the trailing arms.
Seems a bit easier/more guaranteed to fit + I can probably use normal 60mm springs with them and I might be able to mount them upside down.
Apart from that started work on a shed in the garden so I can work on the engine during the the winter (if it's not freezing/too cold :P).
Should have some more exciting updates + pictures the next 2 weeks.
