Old May 10th 2021, 03:33
Nice meaty tyres! And i like the solution you did on the rims of the cookies.
Old May 10th 2021, 05:58
Thanks, it wasn't cheap but neither was buying 3 piece rims so that I could get the correct offset.
I did feel a little guilty having genuine Porsche wheels modified, I'm over it now
Old May 11th 2021, 05:50
Here in the Netherlands a lot of genuine Porsche rims are massacred for the auto cross (widened and narrowed). And after some beating they will end up in the trashcan.....
So don't feel guilty
Old June 5th 2021, 20:29
I took my Beetle out to Powerplay on the weekend, fitted up the new M&H for a few heat cycles (skids)
Old May 9th 2022, 05:11
Finally got a dry Wednesday night so I took my bug out to the drags.
Getting used to launching and shifting gears again, I need some improvement.
I was getting some wheel hop which I'm sure caused me to break a drive shaft. I need to tie the motor and trans down a bit better
Its a custom drive shaft, modified 944 with a 930 CV flange welded on. The guy who made them cant do anything for 5 weeks so I'm trying to organise getting one done so that I can run at the VW Nationals Supersprint.
If anybody knows of someone that could help with welding and machining let me know.
Best ET was 11.803 and best MPH 124.29
Old May 16th 2022, 00:27
Ouch! Sorry you ran into issues!
Old May 17th 2022, 07:37
petevw's Avatar
petevw petevw is offline
oofffff, done that before on a trans output shaft.
'72 super
'65 bus
'52 split
Old November 28th 2022, 20:09
I had some new billet 944 stub axles made in in EN26.
Im fitting some Subaru Group N engine mounts when they turn up from Japan and Ive fitted Superpro urethane bushes to the front engine mount cross member. Hopefully this might help my wheel hop issue
Old November 29th 2022, 03:50
That are some nice pieces sir!
Old July 6th 2024, 21:38
Last year I fitted some twin Spal fans to my 944 radiator. I had to cut the housing a bit to fit them.
I've just fitted dual thermo fan switch in radiator as used in Alfas. It has the same M22 thread that's in my radiator.
The only one I could find with a suitable temperature range was made by Tridion with Operating Temp: 92°C - 87°C & 97°C - 92°C
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
