Old April 9th 2023, 23:26
Scotts73SB's Avatar
Ohh just remembered..i had to change a bolt on the spring plate to a button head bolt. Another thing to check clearance.
Old April 14th 2023, 01:59
Bad bug's Avatar
Bad bug Bad bug is offline
Ah! yes i will be doing this on the spring plate. Where did you get those bolts to buy also since i will be using the 944 trailing arms which shock do you use with the trailing arms. I would like to use koni red adjustable on all fours.
Old April 14th 2023, 23:29
Scotts73SB's Avatar
Mine came in a kit from topline when I got the Maxx struts..Mine is all stock so im using kyb gas i think on the rear.
