Old July 12th 2010, 09:58
Bug@5speed(US)'s Avatar
Tim,
Thanks, they look like they fit quite well the arches of the beetle.. are they fiberglass or plastic?
Thanks for the info..
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old August 5th 2018, 23:53
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Hey,
Did anyone have trouble with the spring plates not sitting on the droop stop?
Old August 7th 2018, 03:10
did you give the chassis a clearance grind for the head of the adjusting bolt?
Old August 8th 2018, 10:39
DORIGTT's Avatar
Hey Steve,
I didn't.
Just that hole is enough to clearance the area?
Will I still be able to use the adjusters for alignment purposes?
Does this require a specific spring plate cover? I've got a 1970 with dual blades on the spring plate, and another person said I need to use the later versions without the spacers on the back so it will suck the Porsche springplate in tighter.
Old August 9th 2018, 02:32
The big nut will drag on the chassis if you dont grind some metal away
You can still get to the toe and camber adjusters, the big nut is hard to turn because the chassis blocks it, I found a thin (36mm I think) spanner on eBay for a clutch fan I think
I used cut down 944 alloy ones on my car with Beetle inner rubbers and 944 urethane outers
you see my 944 outer cover in this photo
Old August 13th 2018, 22:08
DORIGTT's Avatar
I take it that everything lines up properly and all works fine like that eh?
Would running non Porsche covers work?
