Which One???
IF you had a choice to build a great handling and great riding GL Super...... would you pick a 73 or a 74???
(I'm in California, and I don't want anything newer than a 74 for SMOG reasons) Thanks !!!!!!!!!!!!!!!!
74 with the steering fron a 75-up
A 73 would also work with the 75 and up rack and pinion steering...just make sure that it is the latter 73 with the 2 bolt struts, not the earlier struts like on a 71 - 72 super.
How come you can use a 75? It is 2005 now, so it it would be 30 years old this year...
i was also wondering if the rack and pinion setup would work...can it be swapped into a 74.
does the rack and pinion offer any advantages to lowering/handling i have not seen the suspension layout for it..can you go lower with the rnp?..considering the pitman arm on the 74! |
just noticed post in suspension section :whoops:
I believe the 71 or 71 suspensions can go the lowest.... not sure about the difference between 73-74 and the 75's with R&P...
