ahh, did not know that. still wouldn't mind seeing a few articles for the "bastard" vw
heh, i konw it's not a bastard, but thats what all my friends with standards call it |
with the 944 spindles and the 74+ struts, will porsche 17's clear? or should i go with the maxx struts also
I'm running MaxxStruts.
Around here (GL'ville) the Super(ior) is not thought of as a Bastard. It is the bug of choice for most.
I thought it was all going to be simple for an 03 too, but when I researched it isn't just a case of swapping over the spindles and using Kerscher ball joints.
There is also: +ve camber in the Porsche spindles needs correcting (triple C camber bolts?) Extending the tie rods track increase (need late 03 parts which are wider and the brakes add another 10mm per side?) Only early spindles have the speedo cable hole in them. I think a tech article is needed! Rich
http://www.ricola.co.uk |
I thought Superman was writing a tech article ages ago... Cheers Jeremy
1302 RAt "GermanLook" |
he did, but i'd still like to see a full color atricle about it so i can SEE exactly what he's talking about.
well, not so much an article as a thread |
I thought you had already written something, I'm sure I've got articles (all be it forum "thread" based) from yourself discussing all the things to be aware of when doing this conversion. I can't remember where I found them now. Watabug, if all you want to do it fit Porsche Wheels, then sure fit adapters and wider guards, I really wanted bigger brakes, thinking back now, I'm not sure why, but they're on the car now and they work, so I'm not about to fiddle with them in a hurry. Someone starting afresh with little experience, I would point them to vdub engineering http://www.vdubengineering.com/products/brake.htm or V-force http://www.beetleracing.com/catalog/...3e47e9a535169e. Those that are old hands at hotroding will most likely be able to figure things out themselves. CU Jeza
Could the track control arm be made adjustable by welding in an adjustable rod in the middle? This would allow you to fine tune the camber pretty easily. If this was done, would there be difficulties with the top of the strut binding or is there some "flex" up there that would allow the track control arm to be lengthened?
Subaru powered oval/1303 hybrid project |
not to undermind the value of this forums, but superbeetles.com and superbeetlesonly.com have a few tech articles that may be more specific.
I reckon the best way for front super brakes is to use Monoblock calipers as they have radial mounting, then use stock disc brake stubs and have an alloy block made up that bolts to the stock calipers ears, then use a turned down drum or disc hub as your hub for some rotors you can just drop over. Steve
