Air intakes
i was thinking of getting some carbon air intakes from remmele and mounting them in the rear windows with sikoflex , what do you think of that for an idea good or bad
cheers jon
woop woop 67 2276 turbo 64 ghia 1776 zx7rr |
hey man no don't put them in the window put them in front of the rear fenders then make piping to the eng,
Hmmm...
Personally sticking them in windows is a good idea, as your not chopping metal up to fit them, so its easily undone. Plus the higher you get from the ground the cleaner the air (less dust) = less to clog up filters/coolers... Just something to think about. Sam C
1973 1303 (super beetle) in Jaguar British racing green, Raby 2270, B spec gearbox, Lots of carbon fibre, Wolfrace Octane Black 17x7.5, Goodyear Eagle F1's, Kerscher suspension front and rear, kamei airdam in carbon, corbeau seats, momo millunium steering wheel. CDT eurosport 6.5 front speakers, IDMAX 12D2 sub, rockford old school amps. |
hey sam good call , the problem i have is the turbo is over the gearbox so it gets vv hot , i just finshed the outside of the car so dont want to start chopping it up , i thought it would make a interesting look and be a temporary solution to the heat problem until next year
You dont have to go with carbon either... If mounting them in plastic windows you can get clear plastic ones for quite a bit cheaper than the carbon ones....
Sam C
Hey Sam,
How hard was it to mount the air intakes that you have just after your windows? How do you direct the air down to your engine? Do you have any pictures? Thanks, Randy
Unix is a "user friendly" operating system. Its just a little particular who it is friendly to. |
Fairly easy.
They are just screwed to the body ![]() Currently not ducted down to the enginebay, purely cosmetic! (I know I know). If I was to duct it I would take an 80mm holesaw, work out exactly where the pipe would need to go (probably easiest with rear windows removed, can poke head halfway out from inside and see both sides) and drill.... Then mount the pipes down to the firewall or to the area above gearbox (air for oil coolers/intercoolers...) Sam C PS, Good luck trying to get a set of scoops like mine.... They are an original 60's part (empi) that was reproduced by a local company in limited numbers... I bought the last set they made ![]()
