Im thinking of going with the addapters, reason being, if I want to ever go back to the stock size I can.Plus Im looking at the 5-112 pattern and under the 2006 Jetta, theres some nice wheels.Thing is, lets say the addapter is 1/2" thick, what ET rim would I want to look for?Would I want a 15x6.5 in a 40-55et or a 30-40mm et?
http://www.tirerack.com/wheels/Wheel...6&autoModClar= |
If you are interested in '06 Jetta wheels, you should find out what their offsets are. It is easier to work out these problems if you can reduce the variables into being constants.
(2004-2008): 1971 1302 w/2056 Searching for a new project ... |
I looked on VWVortex, an the guys over there say the MKIV Jetta has a 35mm-38mm offset.
i might end up just buying the 4 lug 4-100 drums from cip1 being there 79.95 each, compared to 55.00 addapters.then buy the konig rewinds since there more the style i like.There 15x7's and are 99.95 from this one place in ohio, then buy 8mm spacers for the ones with a 40et, but then i like the rwd version better, only problem with those, is they got 0 backspace, anyone know what to do about that issue,besides really wide fenders lol
Forty millimeters is over an inch and a half. Wide fenders and abandoning the idea are the two best options in my opinion.
(2004-2008): 1971 1302 w/2056 Searching for a new project ... Last edited by oasis; April 30th 2007 at 03:10. |
OK I emailed the company about 2 wheels an I can get the FWD Konig Rewinds in FWD in the color i like which is silver with a polished lip, the color I showed you.They have a +40mm offset, and also weigh 13lbs.
Then I asked about these http://buywheelstoday.com/products/?id=3835 They have a +38mm offset and come solid silver, when I decide which ever one I want, Id get these 15x6.5 with +38mm offset up front, and 15x8 with 0 offset in rear with wider fenders in rear.....the others I dont thnk Id need wider fenders. Also Im going to just use drums so the wheels dont stick out more, and for front run a adjustable beam and tryy to avoid a drop spindle. hopefully this will work....Im more less just researching to see if these options will work.
you can buy blank drums and habve them drilled.
a few pics of my project |
Or I can just buy the 4-100 bolt patterned drums all ready drilled
there the same price.Anyone know how wide of a fender I would need for a 15x8" rim with a 0et? |
