Was going to turbo it but changed mind. Will go with 10:1 CR and 51mm throttle body fuel injection. Not a daily driver you see!
There is a portion of fan that Porsche uses to route air over the cylinders more effectively, but is left out on most conversions. Will have to be trimmed and adujsted for type 1-4 use but well worth the effort. I will scan you a pic of the part so you will see what I am talking about.Part# 18 on the attached pic
Yes i know the bit that you mean
i have fitted an oil cooler in my fan housing type 1 remember without modding the fan housing wher i live a guy near me flys vw powered planes and he use to make the adaptors which i managed to get one of him to retain std cooler also running thermostat and external cooler with mine just hope it will be ok i have ran it up on my test bed and did seem ok ![]()
That's a sweet test bed. Without any shrouding for the oil-cooler, I'd be concerned about airflow. Path of least resistance is around the oil-cooler, not through it.
AMEN Brother!
Nice looking motor. I have about 2,000 ks on a motor in my daily driver/sons car. Its a 1904cc, stock valve heads, mild cam, twin 40 Dells etc. I got rid of the stock cooler and fitted a cooler in the front of the car, doesn't overheat on 30 C plus days, highway or heavy peak hour traffic and warms up quick, I have a fan on it for insurance but its hardly ever needed. Its fitted behind grille in the front apron, but the Kamei blocks it, I'm reluctant to cut the Kamei so the fan is sometimes needed at high speeds. The point I'm trying to make is if your internal cooler doesn't work to well, make sure you fit the external one in a good place. Steve
Hi Steve thanks for advice i do also have an external one fitted with thermostat plumbed in but will be somewhere like above gearbox as dont have option of putting up front like on an 03 model so i hope it will run ok
Is that one of the shifters from Gerd Weiser? It looks Mad!!
Well havn't done much to look at mainly polishing and trying to fit up the front end and work my way back over heres a couple of pics so far
Anyone got any info on different types of headlining i am looking to put something different in bearing in mind my bug is the standard basic 1200 type no headling covering the B and C posts etc ![]() ![]() ![]()
OK been a while on up dates been busy mainly doing electrics and tidying up bits etc so i thought it was time to try and put the motor in
had a problem with the lower engine studs as they appear to short to go through the Porsche box so need longer ones i think type 2 ones are longer but if anyone can put me right on this i would appreciate it ![]() ![]() ![]()
Yes, you need the T2 stud's
Ok so got most of engine plumbed and wired up just need to make bracket for oil thermostat and throttle cable and then time to fire it up i hope !!
