Old December 19th 2012, 17:12
there's a hole in the innerwing ;D. I am going for 6-7deg.caster, -1camber and 0 toe in/out.
Inside of the innerwing, not much space there.
And ofcourse I needed to test a wheel.
Paul.
Old December 22nd 2012, 16:19
Unfortunately I had to little space to move the spindle up n down. after some internet searching, I found out that the golf1 inserts will fit the Porsche strut and is 2" shorter. so I bought a used set to test fit.
if it fits I can shorten the complete strut by 2".
Paul.
Old December 28th 2012, 09:04
Point of no return (again)
I had planned to use more of the Porsche innerwing, but I did not have enough space. Now I only used the upper shockmount and made it 5cm higher. When I find the correct position I will weld it in the innerwing.
Paul.
Old February 22nd 2013, 17:22
Cool last pic Paul! If your shocks turn out to be worn, I have a set of gas-filled Golf-1 shocks for you ;-)
Old February 22nd 2013, 17:52
Thanks Walter,
I'll keep that in mind.
Old February 23rd 2013, 10:58
Today I started by fixating the front wheel (brakedisk) at the wright camber and caster.
Made the innerwing mount to fit the innerwing, fixate everything again and made the first tackwelds. It's coming along just fine I think.
Paul.
Old February 23rd 2013, 11:47
The above picture of the shock dome on the simple 0.8mm thick inner fender does raise the question (I am sure you expected this, but I'am willing to bite anyways) what further stiffening of the inner fender your planning? I know its not load bearing like with a 1303, but still the shock dampening creates considerable forces nontheless.
Old February 23rd 2013, 11:56
Wally,
Yes, the innerwing is deff. not strong enough. But the rollcage will solve that . The rollcage-tubes will run from under the dash to the upper shock mount and ends in the spare wheel well (on the front a-arm mount)
Cheers, Paul.
Old February 23rd 2013, 11:59
That deffo seems like the right way to do it!
Old March 2nd 2013, 09:27
The horn bracket had to move, no suprise what was under there.
So a little repair was needed.
The right front suspension is ready (for now), so it's time to start doing it all again on the left side.
Paul.
Old March 9th 2013, 09:14
Change of plans. I wasn't happy with the A-arm mounts I made in the spare wheel well, so I took out the grinder and started all over again.
No way back now.
Made a new spare wheel well bottom. I will make a lower part in the middle for the battery.
Paul.
Old March 13th 2013, 10:11
The new plan is getting shape.
Paul.
Old March 23rd 2013, 08:42
Today I copied the right A-arm mount to the left.
Now it's time to weld it, grind it and weld it in place.
Paul.
Old March 23rd 2013, 09:20
Wow! Any clarification why you made as you did?
Curious how it turns out.
Old March 23rd 2013, 13:42
Its those Mann filter boxes, they always tell you how to shape it up and do it, they have very special powers
Only one thing springs to mind, now is a good time to add plenty of caster.
