Old September 16th 2012, 15:15
After the new sheetmetal was in shape, It was time to make "the notch"
Made a notch and tacked it in place, it looks a bit odd but the shape is like the original.
And again some trial fitting.
Paul.
Old October 13th 2012, 08:52
Next week I can Finlay work on the car again. the trailer is completely level and the car is welded on it at the wright height.
Paul.
Old October 18th 2012, 15:46
Finlay did some work to the car again
Paul.
Old October 24th 2012, 15:50
1/4 panel is welded up now. IRL it's pretty strait, even without filler.
Also started repairing the innerwing, here it's almost finished
Paul.
Old October 28th 2012, 04:57
A nice fit and welding job again. Nice work.
Old November 28th 2012, 16:48
Is wasn't easy to get the dash near the doorpillar. I finally managed it and it looks good if I say so my self.
Paul.
Old December 1st 2012, 09:44
Right innerwing is almost done, only the marked pieces need some love.
Paul.
Old December 2nd 2012, 05:31
Inching closer. Lots of nice work.
Old December 2nd 2012, 11:13
Yep, slowely where getting there, thanks
Old December 12th 2012, 17:05
After the innerwing was done, it was time to start with the Porsche front beam.
Porsche sheetmetal underneed the spare wheel well
When the car is finished it should not have rake. Now it has a 3,6deg rake, this is why the arm has to be 3,6deg. as well.
Bend and shaped 3mm steel tacked in.
The innerwing has to come out a bid to reinforce the a-arm mounting point.
Paul.
Old December 15th 2012, 17:03
As I told earlyer, I had to widen the innerwing a bit, so I had to try it with cardboard first.
When the cardboard fitted, I made it out of sheetmetal and welded it in.
Then I tack welded the Porsche bracket in place. I just had to try the shockabsorber.
Paul.
Old December 15th 2012, 18:04
I am starting to like your build better and better now your coming to the performance part of it!
Great job Paul, keep at it.
Old December 16th 2012, 05:06
Thanks Wally,
I also like this part better, but the shi(ee)tmetal part had to be done.
Old December 17th 2012, 05:06
Very nice work. Things are really cooking now.
Old December 17th 2012, 16:22
Thanks. After a lot of hours repairing invisible pieces, it is finally time to make some bigger steps.
