Old May 29th 2011, 06:27
-Alex- -Alex- is offline
17" or 18" on a BJ IRS beetle?
I have little "problem", havent yet decided which size wheels + tires planning to buy.
I have 3cm wider front fenders and 6cm wider fenders at rear + early 944 alu arms + coilovers at the front.
Wheels i have decided to get, are these:
http://www.kerscher-tuning.de/raeder/index.php?id=2
Great looking wheel for beetle, i think. Front wheels planned at size 7,5" and et 41, rear wheels 9,5 or 10" and et between 50-60.
Only problem that there is not much choices at tires if i want at back wider than 255 at size of 17", there is few, like 265/40 or 275/40, but these usually cost more than 265/35 18.
Will the ride be much worse if i get 215/40 18 + 265/35 18 tires instead of 215/45 17 + 265/40 17 tires?
I know that these front wheels and tires will fit to front, but what about rear? If the wheels have too much et, spacers can be used, what would be optimal et with these wheel sizes?
Old June 10th 2011, 21:14
speedy's Avatar
speedy speedy is offline
Alex ,
I run 17 7&9 inch wheels 215/255 with a 50-55 offset , my front wings are 40mm oversize rears 60mm, steel 944 rear arms and a 2 inch narrowed front beam , with 996 brakes on the front and rear i require 25mm spacers on the front and 40mm spacers on the rear to sit them just on the inside lip of the arches , your rear arms may be a touch wider but i hope this will give you a better idea about offsets etc , personally i would like a deep dish on the rear wheel so would opt for the smallest offset on the rear to achieve this in my case Et20 on the rear with a 5 mil spacer for adjustment .
Hope this helps
Jonathan
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old September 1st 2011, 13:18
Ok, things have changed. I have bought mendeola a-arm suspension (not yet arrived).
Really have decided to use 18" rims, like 3-piece one used or new. Kerscher wheels are nice because you can choose ET.
Planning to go reasonable , so front 7,5" wheels and rear 9,5" wheels. Wonder what et would best... Maybe at rear 60-73mm and front about 40mm
Old September 3rd 2011, 13:08
onixbonilla's Avatar
onixbonilla onixbonilla is offline
Hi Alex.I would go for the 18".
The ones you choose are excellent choice with the classy looks that
do not age as most modern wheels.
Don't desperate, we will get our Mendeolas in a couple of weeks!!!
Old September 5th 2011, 03:12
Yeah, i will go with 18" wheels. This style wheel is classic but aggressive, i like them.
Old September 6th 2011, 00:40
One thing you need to keep in mind is getting the correct size tyres and stance, get it wrong and car will look like a kids toy.
Old September 6th 2011, 15:31
Yes, thats true. I am planning to put front 215-225/40 R18 and rear 265/35 R18.
Man these wheels look good, even on a porsche...
Old September 7th 2011, 05:04
How wide actually fits to back and how much there is room for backspacing from stock setup? 6cm wider rear fenders, early 944 arms, which widens about 43mm per side with brakes?
Original wheel 4,5 x 15 et34
Kerscher wheel 9,5 x 18 et67 or 73, depends if wheel has flat or high center.
http://www.1010tires.com/WheelOffsetCalculator.asp
67-43 = 24mm
Inner clearance is 53mm less than stock with this setup, probably doesnt fit. Spacers or wheel with less et perhaps? et54 or 60 is next smaller et.
But again, base point for these measurements could be perhaps typical empi 8-spoke which is 5,5x15 et 30 and it fits under stock rear fenders easily. At this calculation, 9,5" et67wheel is still used.
