Old February 15th 2012, 16:48
fahrvergnugen fahrvergnugen is offline
Starting to fit pretty well.
Paul.
If some is good and more is better, then too much should be just about right!
Old March 7th 2012, 16:29
After a testfit of the windshield is was obvious the left corner wasn't wright.
So, out with the grinder again.
On my way again.
The stuff I ordered at Hooky's wasn't in yet, so the corners are done for now.
Just 4 fun, played with the front suspension 8)
Paul.
Old March 7th 2012, 16:55
It already looks low, just sitting there on its stands :=)
Very curieus how that would drive on a track compared to VW front beam! So, get on with it!
Old March 7th 2012, 17:08
It looks pretty low indeed. the good thing is that it has adjustable torsion bars
I am also very curieus about how it handels, just have to wait a little wile.
Old March 8th 2012, 15:46
Hooky delivered some nice parts 8)
To fix the window corners I ordered these repair corners.
Wile I was ordering at Hooky it made sense to order the weber-windows as well.
Paul.
Old April 7th 2012, 16:05
Yesterday indeed was a good Friday, finally had some time to work on the '56.
Windowcorner left is ready.
On the pic it looks rough, but IRL it is pretty smooth.
Leftside of the dash is finished as well.
Ready for a thin layer of lead.
Then it was time to do the innerwing. It didn't fit to the heaterchanel and it was to short due bad repairs in the past.
Paul.
Old April 22nd 2012, 13:25
after welding and cooling it was time for some precision grinding
it's almost straight, just needs a minimum of lead.
Took me a few hours, but its's worth it.
Paul.
Old April 22nd 2012, 22:41
Coming together nicely. Where did you buy the Hooky Webber windows?
Old April 23rd 2012, 02:08
Thanx, I bought them @ hooky's. http://www.hookyspanelshop.com/
Paul.
Old May 26th 2012, 16:19
Today I started fixing the left quarterpanel
I couldn't find a good donor, so I had to make the best of it with the repro panels.
First I shortend it.
After taking some measurements from an original '54, I started hammering.
Just needs a little massage
Paul.
Old June 23rd 2012, 15:51
After some welding and grinding, i am very happy with the result
I still had doubts about the home made steering and changed my mind. I am going for "rack n pinion".
This Peugeot 404 steering will do the trick, the round couple rubber which is original for this Peugeot as well, even has the same bolt width
Paul.
Old June 23rd 2012, 15:53
I think my oval needs service ;D
Old June 30th 2012, 10:12
Looks almost like original.
Paul.
Old June 30th 2012, 11:57
Fine job. You have replaced more metal in this car than almost any project I can remember. And it all looks great.
Old June 30th 2012, 13:00
Thanks for the compliment. When you start a project, look for the best car you can find. I already had this car (was my daily) so I had no choice.
