Old April 11th 2019, 20:33
Bad luck. A VW performance shop I worked in years ago used make seamless steel sleeves to fit over the top section of 92mm barrels to stop them from spreading, could something like that be used on your barrels?
Old April 11th 2019, 22:48
Clatter Clatter is offline
Whooo!! Like a cutting torch!!
Old April 26th 2019, 18:21
Rebuild process started a while back, but I just had the long block back together with the 98mm AA birals.
Other small difference with the former set-up is that I could and have installed under cylinder tins again. They only needed a little shortening, but no biggie.
Oettinger crank, Pauter rods, Pauter cam and gear:
Old April 26th 2019, 20:50
effvee effvee is offline
Smile
Yessss,eye candy
Old April 27th 2019, 05:39
dub_crazee's Avatar
Sorry to hear you’ve had issues wally, did you ever get back on the dyno and up to boost to 1 bar or did this happen before you had the chance?
Classic Car Revivals
www.classiccarrevivals.com
Old April 27th 2019, 05:53
The latter unfortunately. I was very hopefull though, as at just 0.7 bar it already was doubling the hp from the N/A dynorun on the same dyno.
Old April 28th 2019, 12:34
Thought to take a pic before the pulley and cooling parts cover it all:
Like this:
Old April 29th 2019, 12:30
Its ridicoulous: I posted one picture (the above one) of the engine in the flat4 racers section on FB and got 500 likes, 56 shares and 50 responses...
Old April 30th 2019, 19:59
DORIGTT's Avatar
DORIGTT DORIGTT is offline
It's just tough because its hard to search on FB, and most want that instant gratification that it provides.
Old May 4th 2019, 11:58
Almost in again
Old May 4th 2019, 18:24
412STi's Avatar
412STi 412STi is offline
Thumbs up
Greetings Gerold
STi powered Typ4 in the works...
R.I.P. 1302/'72
Old May 9th 2019, 14:38
Engine long block is back in. Hydraulic clutch feels good again.
Test mounted intake (picture) to mark the spot where to install the waterinjection nozzle.
Since my old controller had a short and no replacement parts were made for it anymore (...), the quick and dirty solution was to get the newest kit.
Unfortunately, I really could not reuse even some of the old installed waterlines (slightly different outer diameters), so had to removed all of the older wiring and waterlines... grr! Hate to do wiring, but had to.
Old May 22nd 2019, 18:14
This is going to be fun!!!
Old May 26th 2019, 08:43
Bad bug's Avatar
Bad bug Bad bug is offline
Wally are you running your dry sump tank up front again.
Old May 26th 2019, 15:30
Yep, since ~forever. Some people still think thats a bad idea. Busted that myth long time ago. Its all about how you execute things.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
