Old December 1st 2012, 09:44
fahrvergnugen fahrvergnugen is offline
Right innerwing is almost done, only the marked pieces need some love.
Paul.
If some is good and more is better, then too much should be just about right!
Old December 2nd 2012, 05:31
Inching closer. Lots of nice work.
Old December 2nd 2012, 11:13
Yep, slowely where getting there, thanks
Old December 12th 2012, 17:05
After the innerwing was done, it was time to start with the Porsche front beam.
Porsche sheetmetal underneed the spare wheel well
When the car is finished it should not have rake. Now it has a 3,6deg rake, this is why the arm has to be 3,6deg. as well.
Bend and shaped 3mm steel tacked in.
The innerwing has to come out a bid to reinforce the a-arm mounting point.
Paul.
Old December 15th 2012, 17:03
As I told earlyer, I had to widen the innerwing a bit, so I had to try it with cardboard first.
When the cardboard fitted, I made it out of sheetmetal and welded it in.
Then I tack welded the Porsche bracket in place. I just had to try the shockabsorber.
Paul.
Old December 15th 2012, 18:04
I am starting to like your build better and better now your coming to the performance part of it!
Great job Paul, keep at it.
Old December 16th 2012, 05:06
Thanks Wally,
I also like this part better, but the shi(ee)tmetal part had to be done.
Old December 17th 2012, 05:06
Very nice work. Things are really cooking now.
Old December 17th 2012, 16:22
Thanks. After a lot of hours repairing invisible pieces, it is finally time to make some bigger steps.
Old December 19th 2012, 17:12
there's a hole in the innerwing ;D. I am going for 6-7deg.caster, -1camber and 0 toe in/out.
Inside of the innerwing, not much space there.
And ofcourse I needed to test a wheel.
Paul.
Old December 22nd 2012, 16:19
Unfortunately I had to little space to move the spindle up n down. after some internet searching, I found out that the golf1 inserts will fit the Porsche strut and is 2" shorter. so I bought a used set to test fit.
if it fits I can shorten the complete strut by 2".
Paul.
Old December 28th 2012, 09:04
Point of no return (again)
I had planned to use more of the Porsche innerwing, but I did not have enough space. Now I only used the upper shockmount and made it 5cm higher. When I find the correct position I will weld it in the innerwing.
Paul.
Old February 20th 2013, 16:27
Finally did some work on VWrankenstein again.
Started working on the upper Shock mounts
Took out the rubber, shortend the the Porsche mount and made a plate to close the underside of the Porsche mount.
Test fit the bearing Busch
Underplate fits like a glove.
After some welding and grinding, I fitted the bearing. Looks pretty original. This bearing fits the Golf1 shocks perfectly
Bottomview
Paul.
Old February 22nd 2013, 16:42
Today again found some time for VWrankenstein.
To make sure there was enough space for wheel movement I bought Golf1 shocks. The Golf1 shock are about 5,5cm shorter.
Here's the difference.
Now the struts had to be shortend too.
And again some trail fit. (I used the wrong (too big) wheels)
Paul.
Old February 22nd 2013, 17:22
Cool last pic Paul! If your shocks turn out to be worn, I have a set of gas-filled Golf-1 shocks for you ;-)
