Old October 17th 2013, 00:30
graham's Avatar
graham graham is offline
'56 rag with a twist
Originally Posted by fahrvergnugen View Post
8 cm higher, it has become a short firewall
Paul.
Very smart
gee dub
Old October 17th 2013, 15:41
fahrvergnugen fahrvergnugen is offline
Originally Posted by graham View Post
Very smart
Thanks. This gives me more room for gearbox, engine and future plans
Paul.
If some is good and more is better, then too much should be just about right!
Old October 23rd 2013, 15:39
Made the firewall a bit wider.
Wider piece it tacked in.
The difference.
fits pretty well
Paul.
Old November 6th 2013, 08:44
Firewall starting to take shape. The first weld are made.
Paul.
Old November 13th 2013, 16:38
Now we're flying.
Time for the final things on the chassis.
Old November 13th 2013, 17:06
Gerrelt's Avatar
Gerrelt Gerrelt is offline
Looking good!
Greetings!
________Gerrelt
________homepage:gerrelt.nl
Old November 13th 2013, 22:42
Coming along nicely!
Old November 14th 2013, 02:04
Rule09 Rule09 is offline
Very nice build!
Old November 14th 2013, 15:36
Thanks guy's. The end is just a few welding wire roll's away
Old November 15th 2013, 16:30
The R&P was only temp tacked in place when the body was on. Back then I had to ditch the sway bar.
Today I welded the R&P brackets in its final place, made new brackets for the sway bar, mounted the sway bar and R&P and made brackets to mount the body to the chassis.
Paul.
Old November 15th 2013, 17:18
Now the front is done, I started on the rear. The aligning is pretty good.
Paul.
Old December 4th 2013, 09:09
Not much progress lately. I am supporting son's football matches more than working on the beetle.
Made 2 holes to weld the cage mounting points in.
Dropped the body back on the pan and trial fitted the tubes that go to the gearbox. When these tubes fit properly I can start on the shock mounts.
Paul.
Old December 18th 2013, 16:50
Very small update.
Made some extra room for the gearbox by inverting the bent. Trying it look original
Paul.
Old December 23rd 2013, 16:55
My route is not always the easy route.
Vwrankenstein's notch will be made of original sheet metal. Even to close the gab, of the shortened firewall, i am using modified original sheet metal. I hope that when it's finished this will give an original look.
Paul.
Old December 24th 2013, 11:50
Gerrelt's Avatar
Looks good!
Greetings!
________Gerrelt
