Old September 25th 2006, 21:26
As long as you don't mind hacking and have a very good grasp of suspension design, anything is possible. I don't remember if the Mustangs spindle steering arms are high or low. I used VW because they are high and clear the shifter tunnel.
Old September 25th 2006, 22:26
MikeVW's Avatar
MikeVW MikeVW is offline
The mustang II has lower steer and I believe the steering arms are in front. The good part about the mustang setup is that you don't need to know much about steering design because it has been perfected in the setup. You just need to be good at fabricating and attaching the new suspension. I think most of the tunnel would be hacked away to make room for this proposed suspension.
Mike
http://www.Type1R.com
Old September 26th 2006, 00:10
Originally Posted by Panelfantastic View Post
Not overly obvious LT. Jason's whole mission was to make it "bolt on" to any stock pan without having to hack-n-whack. He could have saved a ton of time and money doing it your way but he refuses to be sensible .
Have you seen the arse end of his car? ...but he doesn't want to cut the front !
(Lets see how long it takes dent to rip me a new one... )
Jeff-
He he, I missed this one! Jeff states the truth, I'm crazy. But it turns out there is a method to my madness. I've been looking into working with a guy from Thailand to modify and and mass produce a better version of what I've already made. Wouldn't you like to bolt up a serious suspension on your bug, built for your bug, and with minor body mods?!!
Just making a front end is easy, making it bolt on with minor modifications, priceless...
Old September 26th 2006, 00:19
Mikey's Avatar
Mikey Mikey is offline
Jeff-
You noticed that too? I noticed it a while back, but I couldn't think of a good way to ask about it or point it out with out sounding smart@$$.
Mike
'04 R32 Tornado Red
Old September 26th 2006, 01:15
It's my rolling test lab, what can I say?!!
Old September 26th 2006, 07:26
GS guy GS guy is offline
FWIW The Mustang II front suspension isn't the best from a geometry perspective for optimized handling. Sure, it's an A-arm layout but was designed back in the 70's to do a decent job and be inexpensive to mass produce. It's a parallel unequal length layout that doesn't provide very good camber gain and lots of in/out scrub. OK for a hot-rod but not the best if you're wanting "sports car" handling. However, it's still relatively inexpensive with lots of aftermarket versions available - I'm fitting a version of it to my fiberglass body (tube chassis) buggy. I'm going to alter the geometry a little and with the limited suspension travel it shouldn't be too bad. Ideally, you'd lengthen the a-arms (from the stock geometry) and re-work the pick-up points but I don't have room in the buggy for longer arms. Also the spindles aren't really that ideal either, pick-up points require mounting the spindle high (relative to the chassis) - the axle is very low on the spindle. When you start really working the parts for improved geometry you eventually find you'd be better off just starting with a better spindle to start with and working in from there!
I've read ATS is (or will be at some point) coming out with an improved version of the M-II spindle, but that may be quite some time from now...
On the plus side, it was designed to carry the weight of a V8 so the bearings and ball joints are quite a bit beefier than VW (but not "too massive") - great from a performance perspective. Also, with the Chassis Shop/Wilwood brakes the spindle/brake/hub package is significantly lighter than standard VW items even with a bigger rotor size! Built-in domestic bolt pattern comes with the package.
Jeff
Old September 26th 2006, 16:23
Last Triumph Last Triumph is offline
My theory is this.
I'd love to build the perfect front end for a Beelte, but I don't have access to the maths to work it out.
I'd love to bolt an optimised system straight to my frame head and 'drive away' but nobody make a commercially available system yet....?
Even if I did design my own system, I understand that just one of the elements needs to be only slightly out to screw everything up so it would end up being dreadful anyway.
The VW trailing arm is very poor anyway so it doesn't take much to improve on it.
Whilst the MII system is by no means perfect, it is a pretty good effort and certainly a massive improvement on standard.
It allows the easy fitment of big brakes, comes in attractive chrome finshes with many variable options and is complete as a unit including steering.
If someone can come up with an easier, cheaper and more optimized bolt on system, let me know?
On the basis that I'll be doing an IRS conversion, chopping a G50 trans into the pan, cutting off a frame head and fabricating mounts for an all in one front end shouln't be too difficult as long as it's correctly jigged and mounted?
Old October 3rd 2006, 22:18
Sounds great. Just think about it LONG and HARD. There are soooo many variables to consider when it comes to adding suspension, especially if you want to limit cutting/welding. How will your steering column integrate into the new steering setup, will your tie rods have room to move, where will your rack sit, how will the angles end up, etc. Lots and lots of variables. It can definately be done and really, like you say, it shouldn't be that difficult. Mine had a lot of restrictions due to the parameter limits I set, but if you don't mind doing using American parts and doing some cutting, it really won't be too terrible. Keep in mind that the Mustang II suspension was designed for a car much wider than a bug, so roll center needs to be adjusted. Remember the results need to be worth the effort.
Old October 4th 2006, 15:22
Panelfantastic's Avatar
Jason,
When you gonna pull the trigger on this Thailand option? I'd like to hear what sort of impact on pricing, the mass production will have. The killer is gonna be how many units you have to buy to get a decent deal. Be sure you get a pre production version to test before they do a full run... then send it to me so I can evaluate it .
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old October 5th 2006, 00:41
PM sent.
Old January 7th 2007, 19:32
alt+f4 alt+f4 is offline
Is this dead or still alive....havnt heards anythign in a bit.
Old January 7th 2007, 23:57
poor boy poor boy is offline
i'm still waiting also. great concept. would love to be able to keep up with my wife's gti when we go out driving and hitting the corners hard.
Old February 8th 2007, 19:29
Cohibra45's Avatar
Cohibra45 Cohibra45 is offline
Jason,
PM sent...
Kelly (Cohibra45)
Old February 9th 2007, 00:15
what is pm sent?
Old February 9th 2007, 00:42
EvilAngel's Avatar
"PM sent"
PM = Private message.
He meant he sent Jason a Private Message
________________________
Engine: Planning Stage
Transmission: Planning Stage
