Old May 14th 2009, 06:50
gonebuggy's Avatar
Pete,
Empi in fact makes two different styles of drive flanges. The ones with the "HD" bolts (3/8) and ones with stock (M8) I went through this myself. I eventually got a pair with the M8 thread. I think Greg got mine through Rancho. I know Cip1 only lists the 3/8.
You should be able to drill out the CVs if that's the route you go. In a drill press, use a slow rpm (200 or slower) and a fast feed on the handle. To my recollection CVs are case hardened on the wear surfaces for about 1/32 or so. So you shouldn't have to worry about contacting that. If in fact there are a few hard spots, you may need to sharpen the drill a few times. Just sucks that you'll have to clean and repack each one to ensure no chips get lodged in there! Best of luck!
PS I have stock axles/cvs and flanges you can borrow for the trip if that helps.
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old May 14th 2009, 09:42
fast Ed's Avatar
fast Ed fast Ed is offline
3/8" is closer in size to 10 mm, so you should have enough meat there to drill them out and rethread. What a biotch that is ... good luck with it.
cheers
Ed N.
Old May 14th 2009, 10:38
flat flat is offline
Originally Posted by petevw View Post
Ed, plan is to drive back Sunday after the show.
Meet at the Tim's on the north side of the 401 and Hwy 25 (Milton)? Time?
Boy am i having a hard time getting this super back together with the stock trans.
Sounds good. 2pm? What about Bryan? Meet you further down the road at a service center?
www.vdubengineering.com
Old May 15th 2009, 14:14
CLKWRK's Avatar
CLKWRK CLKWRK is offline
Yeah I can meet up at hwy 25,
ED - where do you live?
It is possible that I have the gold car sold tonite, if that is the case then I might be breaking the "dubs only rule"
GL ghia restoration:
Old May 15th 2009, 15:15
fast Ed's Avatar
Bryan, I'm up in Caledon. I've sent a p.m. to Lanner, to find out if I can maybe leave my car at his place, and get a ride down to Milton from there.
thx,
Ed N.
Old May 15th 2009, 15:36
CLKWRK's Avatar
yeah i pick up the porsche tonight from steve at MPS, he had to tear down the entire left bank to get all the bottom studs out.
Turns out that engine has never been torn down since it was built in 1980 and still has a hone!
Cost more than I expected, but its done right .... now I'm poor
Old May 15th 2009, 23:00
petevw's Avatar
petevw petevw is offline
Drilled out the CV's last night. Went well with a carbide drill bit.
Today got the driveshafts, trans, and engine back in. All solo. Boy am i sore!
Snapped a 12pt socket on the CV bolts, so the passenger side is finger tight untill i get another at CT in the morning. Pulled the shifter out as it wasn't shifting properly(hopefully its not the trans ). Hope to get it all working by noon tommorrow.
If not, i'll be rolling in the other dub, the TDI.
Weather is calling for rain all day.......
So.... 2pm at the Tim's on Hwy 25, north of the 401.
'72 super
'65 bus
'52 split
Old May 15th 2009, 23:05
TunedPerfection's Avatar
TunedPerfection TunedPerfection is offline
Good luck getting the 12 pt at crappy tire. At my location they had no clue what I meant. I could meet you in Oakville with mine at 10:30am tomorrow. Let me know.
Old May 16th 2009, 00:39
petevw's Avatar
Thanks Greg, i'll let you know.
'72 super
'65 bus
'52 split
Old May 16th 2009, 02:49
CLKWRK's Avatar
Ok heres the deal, gold car is gone, porsche is not finished yet
I am officially car-less
I will try to get the audi
Old May 16th 2009, 03:36
petevw's Avatar
Terrible, 3:30am and just put the tools down. It better be good to go.
'72 super
'65 bus
'52 split
Old May 16th 2009, 11:47
petevw's Avatar
Throwing in the towel.
Can't get the trans to neutral. Can get what i think is R-2-4 but no neutral-1-3. Tried 2 shifters, and a pair of vice grips on the trans shaft. Something's not right. Need to pull the nosecone and see what's up.
It'll all come out again on Monday.
See'ya later.
'72 super
'65 bus
'52 split
Old May 19th 2009, 01:20
petevw's Avatar
Was a good weekend.
Time to post some pics............
'72 super
'65 bus
'52 split
Old May 19th 2009, 08:57
fast Ed's Avatar
I had fun, that was my first ride ever in a Split Bus. Thanks everyone for putting up with my newbie questions and comments.
Will post up some photos once I get them unloaded from my camera.
cheers
Ed N.
67 Beetle Sedan
95 Taurus SHO
89 Mustang GT
Old May 19th 2009, 11:40
gonebuggy's Avatar
Tell me about the trip boys! Wish I could of been there!
I have been rockin' my bug all weekend though. Damn I'm starting to miss my stroker motor
1970 Bug
