Old February 10th 2010, 03:16
was the inner vw bushing loose when you installed it? Any other issues when installing the 944 setup? Thanks.
T4 2666 1303s
Old February 11th 2010, 06:27
Wally, JMD, what shocks are you using at the rear with the 944 setup?
Thanks.
T4 2666 1303s
Old February 11th 2010, 07:19
-Alex- -Alex- is offline
I did the same too, little heat and grinder with wire wheel. Actually fire didnt help wery much, so i teared the rest of rubber with knife and pliers, then tried wire wheel, worked great.
Next step is to send the plates and hardware to electric zink plating.
Old February 11th 2010, 08:34
I always burn out the old bushes as it usually means less hard work and less of a danger of cutting into the housing when using a hacksaw. I've now got lazy and light the Bar-B-Q and drop the whole arm on (Yum Yum) to burn the bushes out.
Old February 11th 2010, 13:05
Actually big heavy wirewheel worked wery well with angle grinder.
Old February 11th 2010, 14:58
Thanks.
I still use the Bilstein gas shocks for VW IRS I bought 20 years ago. They have worked on my typ 3's (squarebacks) and 1303 bugs on all the cars I drove since...
They work very well, but I always feel they should have been a little bit shorter as I fear bottoming them out. My (shortenend) bump stops have always prevented this I think, but would have liked a little more travel out of them so I cold shorten the bump stops an inch more..
Oh, I did of course bore out the bottom 12mm mount for the porsche's 14mm bolts. A dedicated (porsche) shock with 14mm from the start would be better of course.
Old February 12th 2010, 08:41
Hi Wally, aren't your dampers passed their best by now? I know Bilys are durable but 20 years is a long time - unless of course they are rebuildable?
I also bored out the bush for the 14mm Porsche bolt on the Spax dampers we fitted, but it occurred to me that a standard 14mm steel bush pressed in to the 12mm rubber might also work giving a greater preload to the bush i.e. making it stiffer as well as giving a better crush resistance compared to a bored out steel bush?
Old February 12th 2010, 10:32
Yeah, I hear you. I have been holding that of for a good solution for now and I can't invest all at once either
Thats a real good idea. Never thought that was possible tho. I have also seen nice heim-like joints (unibolts?) for the bottom bolt, which would mean getting rid of the rubber all at once. Not sure if they will fit any lower shock eye.
Old February 12th 2010, 12:21
....... I have also seen nice heim-like joints (unibolts?) for the bottom bolt, which would mean getting rid of the rubber all at once. Not sure if they will fit any lower shock eye.
You mean spherical bearings? In principle I don't see why they wouldn't fit however, there are several considerations:
1) The bottom ring is usually concave in section i.e. bell'd. The bearing would have to be pressed in.
2) The ring size would have to be between 34 - 41.2mm dia depending on the selected bearing - teflon lined would be preferred.
3) The race would have to be staked in and a good press fit to stop the race spinning
The minimum race size of 34mm sounds too large for the normal bottom eye ring? The best option would be to include a sleeve as well to the outside of the bearing so that the whole lot could be accurately machined but I don't think the spec is available.
Having said all of that Ricola's Pro-tech dampers look like an affordable proposition especially as they are made to order with I assume the potential of different eye bolt diameters. It's time to pension Billy off.
Old February 12th 2010, 13:07
Yeah, sferical bearings.
and I agree on the last bit
Old February 22nd 2010, 21:56
jmd's Avatar
jmd jmd is offline
clive you want to get involved in a group buy from protech? I am stateside and am pondering the costs of shipping... anyone else? we can all get into a new setup?!
I am still sourcing this solution and have recently stumbled into a problem. I can't seem to find the pitch for the 14mm bolt in the 944 trailing arm. Anyone know?
Old February 23rd 2010, 08:50
Hi having got the spec that I wanted with a brand new set of Spax on the rear as well as a pair of 23.5mm TBs I couldn't justify the expense, although thanks for the consideration.
Aren't they M14x1.5? You can check with a standard wheel bolt (if its long enough)
