Old January 18th 2010, 20:30
Jak Rizzo said he doesn't have any problems with water in his similar intake and his is a daily driver. If I do, I will put a small drain tube on the wing side of the filter box...
I thought someone said something about it before, but couldn't remember
Build is looking good!!
Old January 26th 2010, 18:41
Pair of pro-tech dampers for the rear end (15" open, 10" closed), they only have 125lb/inch springs as I still have the 'short' torsion bars which will be stiffer than the original IRS longer bars, together they should be about right for the heavier engine and trans.
I went for the biggest bushes pro-tech had and didn't need any spacers at the top mounting, small ones either side at the lower end.
I held a G50 911 axle in position and luckily it looks like there will be enough clearance to the spring. Normally this wouldn't be an issue but with the trans moved forwards it was something I needed to check...
Paneling part way through, just section by air filter to do now and some general tidying up...
Old January 29th 2010, 19:58
Rob's Avatar
Rob Rob is offline
Unbelievable work Rich, that's just crazy.
Are you a metal worker by profession ? That's some amazing work!
Old January 30th 2010, 15:48
Lol, not a metalworker or even close, this is my first attempt at this sort of thing! I'm a mechanical design engineer, designing electric power steering stuff mostly...
I put the engine/trans back in today to sort a few brackets etc out...
Old January 30th 2010, 18:57
chug_A_bug's Avatar
that's some Crazy Fab work... Looks great
can't wait to see this done.
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old January 30th 2010, 19:26
Xellex's Avatar
Xellex Xellex is offline
Sorry for the offtopic, but do you by any chance have, or can source the internal schematics for the electric power steering pump used in the vw fox, lupo, polo, the Seat cordoba, ibiza, and Skoda fabia?
It's the pump that I'm trying to use in my setup, but normally it had this sensor on the steering column, that gave the signal to the pump to start only when the steering wheel was manually turned or something like that. I'd like to override that somehow.
This is what it looks like, and all I could find was that schematic, in that quality and language )
www.vw1303s.com
Old January 31st 2010, 06:20
dub_crazee's Avatar
looking good - its really coming along now! how much did the coil overs set you back if you dont mind me asking.
Classic Car Revivals
www.classiccarrevivals.com
Old January 31st 2010, 16:38
Sorry Xellex, that's not one of our (TRW) systems...
Dampers are £80+VAT each, bargain compared to other stuff out there IMO..
Done some more bits and pieces. Put the engine/trans back in to finalise placement of a lot of ancillaries..
Paneling now done, might add another few fixings depending on how it they are with a foam seal in place
MAF side of the air filter assembly done, MAF bolts on to the side of the housing, reducing elbow connects to original Subaru turbo intake pipe.
Old January 31st 2010, 17:17
bamberjim's Avatar
bamberjim bamberjim is offline
Awesome work...
Old January 31st 2010, 23:34
WOW! That is looking great!
Old February 1st 2010, 03:20
Jim's Avatar
Jim Jim is offline
fantastic build!
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old February 1st 2010, 09:29
Very impressive sight of the rear end with the wheels on!
Old February 1st 2010, 10:45
TSAF's Avatar
TSAF TSAF is offline
Very good metalwork and trust me I know a lot about metal works.
VW 1303s 1975 (German Look)
VW 1300 1964 (Rally Car)
LAND ROVER DEFENDER 90 V8
BMW E30 318i CONVERTIBLE 1992
Old February 2nd 2010, 18:04
Additional brace to support the rear bumper mount. It is now strong enough that I can lift the body off the chassis with no flexing but still unbolts to aid engine removal.
Old February 3rd 2010, 23:22
effvee effvee is offline
Engine location
Hi, this picture is a very good picture for me to as a question. I believe I mentioned some time ago, I would love to try the 6 cylinder. Here goes my question.
1. by moding the tunnel and using the coilover shocks, do you believe the 6 cylinder will fit using a 915 trans?
