Old July 24th 2010, 19:24
seangfy seangfy is offline
few updates and new pics
installed the engine for the first mock up of things ended up not being able to move my trans any ferther foward so had to settel with the timeing covers sticking out of the body but ohwhell.
hear are some pics
plan on making small domes to cover the timming covers shouldent look to bad when im done.
Old July 25th 2010, 13:44
What about using the bug@5speed nosecone on the trans? That should move it far enough to get things under the bodywork without cutting the torsion bar housing...
Old July 25th 2010, 15:05
i have the stock 911 nose cone milled down and welded up i halve about a half of an inch more that the trans can move forward but then i will have to remake all of my mounts plus relocate my slave cylender wich i have mounted between the frame horn and the gear box so i ill deal with a little body work should be fun to make look good.
some more updates finaly found my camara to take some more recent pics
turbo and intercooler mocked up for the first time
body is not going to be as bad as i thought
Old July 28th 2010, 22:14
Pingar Pingar is offline
Its looking good. Keep at it!
Old August 19th 2010, 01:36
hears a few new pics pulled everything back out and cut the body back a bit to try and slide the trans a little ferther back got about a 1/4 inch more dont think it will help much but worth the try also have the engine on the stand redy to make my wiring harness for the ecu wich i finaly finished will post pics of that soon
Old August 19th 2010, 09:25
Eatoniashoprat's Avatar
Progress is good!
Is that a wrx intercooler? If it is and you're planning on more boost than stock I'd consider getting an STi or Perrin one. Not only from a cooling perspective but also flow, the stock wrx one I believe is a little restrictive at higher boost numbers (15+).
1302 EJ20 turbo
Old August 19th 2010, 11:16
V8SuperBeetle's Avatar
V8SuperBeetle V8SuperBeetle is offline
Cool swap. Looking good so far.
Old August 20th 2010, 00:03
going to keep the boost close to stock for now so that should do at the moment will upgrade later
Old August 31st 2010, 11:32
vugbug71's Avatar
vugbug71 vugbug71 is offline
looking good! that should be loads of fun when you get done, how much heavier is the suby engine than a vw engine?
