Closed Thread
Old March 25th 2011, 14:22
coolrydes coolrydes is offline
Here's our all new Super Beetle kit ready for shipment. This one is going to France. This new kits allows for not only type 1302 and 1303 s to use our kit but is also very custom chassis friendly. Take a look at www.thesamba.com under general parts in the classifieds for futher info on these kits.
  #17
Old March 25th 2011, 20:42
Looking good!!! Do you guys use standard or metric hardware?
  #18
Old March 28th 2011, 07:27
I see the bottom bracket of the coilover is very low. How does it look with the wheel/brake combination assembled on it? how much ground clearance is there with a standard 640mm o/a dia wheel and tyre on?
  #19
Old March 28th 2011, 15:04
Thank you for the kind words.
All of the gold hardware is 1/2 standard because getting metric in our area from the local bolts houses is super hard . I would prefer to use all metric. We do you metric on the sway bar and rack mounts.
  #20
Old March 28th 2011, 15:13
I thought the same thing the first time I looked at it, then the engineer pointed out the fact that it is in line with the spindle. This means that anything that goes under the wheel will lift the suspension the same amount.
Here is a picture of the Speedwell oval with 17 inch wheels and a 195/40 tyre.
  #21
Old March 29th 2011, 06:59
You certainly can't see the bracket in the photo that means that it is above that car's lowest point. The bottom bracket does move up and down with the wheel so the clearance with the road remains reasonably constant but I couldn't work out what that dimension was and it looks as though it will be inboard of the wheel inner edge.
Old March 29th 2011, 20:53
What is the lb/in rate you guys like to use for these?
  #23
Old March 30th 2011, 16:26
Here is a better picture with 17 inch wheels
  #24
Old March 30th 2011, 16:27
I do not understand what you are asking here?
"What is the lb/in rate you guys like to use for these?"
  #25
Old March 30th 2011, 18:52
I'll put one of these units in list of things I need when rich.
Do you have any photos of how it attaches the super bug frame head? Just curious.
PS Beautiful work
  #26
Old March 30th 2011, 20:53
When you purchase aftermarket springs that are for no specific application you generally buy based on:
1) Overall diameter
2) Length
3) Spring rate
In North America as far as I've ever seen the spring rate is measured in pounds per inch (lb/in), that is a one inch depression of the spring will be able to resist a specific weight. So, a 180lb/in spring will be able to support 180lbs when depressed one inch, 360lbs for 2 inches of compression, etc. Some springs are wound in such a way that they are progressive, so the more they are compressed the more they actually resist being compressed, but those don't seem to be as commonly used as the one to one lb/in measurement.
Sway bars don't affect the spring rate if both sides are compressed together, but if one is compressed more than the other, the additional spring rate of the torsion bar can be added to that of the actual spring.
  #27
Old March 31st 2011, 17:23
1) Overall diameter
2) Length
3) Spring rate
Ok now I understand what you were asking. Our standard spring rate is 250lbs. However we can go higher or lower as needed for different car weights and applications. We can also change shock valving to suit a certain use.
  #28
Old April 5th 2011, 05:07
Thanks for the photo, it shows what I feared in that the bottom coilover mount would be vulnerable to road and kerb damage over here.
From the overall layout it occurred to me that it has the potential for inboard coilover mounts operated by rockers?
Old April 6th 2011, 11:03
Yes,
you could rocker them, however the stock tank may have to be lifted enough for the shocks to clear.
  #30
Old June 28th 2011, 12:25
flat flat is offline
I just did a brake setup for a Mendeola a-arm system. BoxsterS/993:
www.vdubengineering.com
Closed Thread
