Old October 2nd 2010, 06:28
Great to see your project here in summerised form Paul!
This made me appreciate your work even more as it made more sense to me now. Its otherwise easy to get lost in endless details....
I also don't wanna know how many grinding disks you've used haha!
Old October 2nd 2010, 09:01
fahrvergnugen fahrvergnugen is offline
After 3 week doing nothing on the car, I finally started again.
The left crosmember is ready, so it is time to start on the right side.
This is where I started with.
And the result after hammering, grinding, bending, cutting and welding a few hours.
Almost there 8)
Paul.
If some is good and more is better, then too much should be just about right!
Old October 2nd 2010, 09:08
It looks like you have a rigid outer (hole in steel plate) and a urethane surrounded inner mount, this will lead to movement and potential fatigue in the bolt. I think if you just made the inner part rigid it would be good (much better than a lot of other kits that use loose outer plates...
Hi Rich, I love reading about your build. You do awsome work.
You saw that right about the inner mount, my first version (like manny sets out there) where bolted only on the outside of the steel plate. This new version has a 12.9 bolt with a precision hole in the steel plate and uniball, the urethane is extra and not really needed (I think/hope)
Cheers, Paul.
Old October 2nd 2010, 09:16
Hi Wally, yeah I followd you to this place.
I have the same feeling about loosing it in the details and have to look tru all my pictures from now and then to see what I have done.
I have used a few grinding disks and like volksdent sayed; welding wire, and I only just started. Still have a lot of plans and tricks up my sleeve
Paul.
Old October 2nd 2010, 09:37
Originally Posted by Xellex View Post
I often read through the Keversite forums with the help of google translate :P
That will be some funny reading
Old October 3rd 2010, 20:29
flat flat is offline
Wow. Amazing work! I'm going to keep my eyes posted on this built!
www.vdubengineering.com
Old October 4th 2010, 18:07
Good to see you have made progress since I last looked at your main thread! One thing I'm not sure about is the inner bit of your spherical bearing mount. It looks like you have a rigid outer (hole in steel plate) and a urethane surrounded inner mount, this will lead to movement and potential fatigue in the bolt. I think if you just made the inner part rigid it would be good (much better than a lot of other kits that use loose outer plates...
Agreed.
Old October 9th 2010, 11:43
Finally the crosmember is done, When the body is on it's place i will modify the endpieces of the crosmember and probably do the bumb over again.
The heaterchannel was to long on the front and to short on the rear, I did not want to redrill my floor so I had to dismantle the channel.
The bottom of the channel will be mounted on the floor and then make the top fit.
Looks nice on the inside
Now that I opened the channel, I bare metaled the bottom and I will put some decent paint on it
Paul.
Old October 16th 2010, 15:24
After I painted the inside and bottom of the channel, I sprayed antirust on it and some inox spray on the welding areas. Now it was time to fit it in it's new position..
I placed the channel 1/2 an inch backwards on the bottomplate.
Back fits like a glove now.
The firewall can be mounted without a problem
Paul
Old October 17th 2010, 12:11
Awesome project!! Very cool ideas especially with the narrowed rear suspension - Very trick! Very well done!
Old October 17th 2010, 14:08
Thanks, I realy love doing it
Old October 27th 2010, 15:43
Finally the channel is ready, but after welding and grinding it was torn a lot >
So I fixated the channel and fired up the torch, after it was heated I tried to torn it back.
And that worked.
Next step is the firewall, I decided to use and repair the leftovers Tikimadness donated.
Paul.
Old October 30th 2010, 15:12
Today I cleaned up the firewall that was cut out of a '54. The firewall or innerwings where replaced or repaired in the past, it was not spotwelded but had a lot of welds around the edges. But it came out pretty nice.
This firewall was cut out because of it's weight, but the heaterchannels had to stay. this is why I had to repair the corners, it was not rusted but cut around the heaterchannels.
Paul.
Old November 6th 2010, 09:42
Done.
Paul.
Old November 10th 2010, 16:25
After some grinding, bending, drilling and a lot of hammering, the left channel fits properly.
