Old January 25th 2011, 01:39
SportyBug SportyBug is offline
F4P, are you making camber plates that work with the 1303?
Old January 25th 2011, 03:28
F4P's Avatar
F4P F4P is offline
yes they fit on 1302 or 1303
www.flat4parts.com
Old January 26th 2011, 01:16
Humble's Avatar
Humble Humble is offline
I bought a set of the F4P camber plates and I'll vouch for the quality, good stuff!
As for a strut for the front, A1 golf/rabbit 76-84 has a very short strut, one of the shortest, so you might try one of those.
Old January 26th 2011, 05:11
F4P's Avatar
F4P F4P is offline
thank's humble i reajust my 3d symulation with bilstein p30-0137 and it works great
so let's go
www.flat4parts.com
Old January 31st 2011, 14:33
Eatoniashoprat's Avatar
so let's go
Last summer I ran the bilstein P30-0032-M0 (rabbit sport strut) with 150lb/in springs in the front and to me, the inserts were WAY too stiff. The were rock hard and I actually lost braking grip because the suspension wouldn't move fast enough. I'm looking to get them revalved for next year.
I put the inserts in with 75 lb/in springs (which were way to soft) also just to see and the struts still made it feel rock hard.
What sort of simulation are you using? I have yet to try calculating compression/rebound settings.
Mike
1302 EJ20 turbo
Old February 1st 2011, 05:18
F4P's Avatar
F4P F4P is offline
the simulation is not for calculating spring or valving it's " only" to know if the struts can work fine in length.
i can't calculate spring or valving yet i don't know the final weight of the car in the front
www.flat4parts.com
Old February 1st 2011, 10:21
Ok thanks. Just thought I'd add my two cents, amazing project by the way!
1302 EJ20 turbo
Old February 2nd 2011, 15:45
I would advice you to raise the trans before going further to the point of no return, a lot..... your shaft angles will make short work of the cv's and sap engine power.
Old February 4th 2011, 22:28
Bugscandrift Bugscandrift is offline
AWESOME!!!!!!
Hurry up and post some updates.. This is making my 1915 turbo look like an old dog!
If god had meant people to walk, whyd he invent cars?
Old February 5th 2011, 11:55
Bad bug's Avatar
Bad bug Bad bug is offline
Bugscandrift, how is your 1915 turbo, does it make good power and does all that power come in at a low RPM. I am thinking of building a 1915cc t1 engine first before i build my t4 then the waterboxer.
Old February 5th 2011, 13:40
Ill let you know once I get it running.. Its close... Real close.. I actually have been working on it all day, but Im taking a break for lunch right now..
Old September 18th 2011, 01:53
knopis knopis is offline
any progress?
