Old May 19th 2012, 09:07
rennsport rennsport is offline
After this major upgrade, I ll tryinf to collect parts for the mecanical upgrade..
EJ25 and Porsche 915 gearbox
the oil sump from Martin Bott
Porsche gearbox plate
throttle body reverser from RJES
throttle cable
fuel filter
Bosch fuel pump
speed sensor from RJES
Cosworth oil control baffle
the engine from a Legacy ( EJ25)
http://www.youtube.com/watch?v=2xl7MBe9RPw
Porsche 915/12 gearbox and shifter
plate from DS Tuning
wiring harness
VDO gauges sensor
header tank
water gauge
oil gauge
Vw rabbit GTI rads
master cylinder for the hydraulic handbrake
line lock
Mocal plates
Old May 19th 2012, 09:09
hydro handbrake
MC fit
LINE LOC
Sub parts
Porsche parts
ring of towing before painting
Porsche flywheel ring gear
Porsche clutch and Sub belt
the new plate
detailling
Old May 19th 2012, 09:22
new leather seat
try to see ...
at work ..
no many place for a girl
Old May 19th 2012, 09:29
june 2011
preparing the engine, bad news for the gearbox, some parts broken into it, need to buy another one cause it was to expensive to repare it, I ve found a 915/62 more longer and alu case...
mod on the baffle
cutting the oil sucker
I bought a Wevo shifter
Old May 19th 2012, 14:50
Very cool project. Keep the pix coming.
Old May 20th 2012, 08:07
JULY 2011
engine out
Welded supports
fitting the gearbox
engine in place
I fit the seats and connect the driver one
engine and gearbox
replace H4 bulb by HID bi xenon
rads in place
dashboard mod
problems on the exhaust...
fuel tank mods
T3 parts
small panneling for the ecu and the sub wiring harness
water gauge sensor
the exhaust after cutting and correct rewelding
in place
too low , so cutting and welding
another in place
good
:mrgreen:
panneling
the gauges in place
Old May 20th 2012, 11:56
1st test
http://youtu.be/NaedQNkpuLw
before changing exhaust
http://www.youtube.com/watch?v=t9swDy8eIVA
detailling
nouvelle grille de boite sur le cendrier
dangerous mushroom !
Old May 20th 2012, 12:28
Super nice. Love the details. You did some very fine work and it has turned out great.
Old May 20th 2012, 13:17
THANKS
now I fit a RJES exhaust but I loose perf , it looks better but I think I need to make another one like it with bigger tubes
http://www.youtube.com/watch?v=r8kwU...layer_embedded
Old May 20th 2012, 14:12
Nice to see the full history of the bus on here, I keep an eye on GL.org for an extra dose of GL
Old May 20th 2012, 14:24
Hi Rich
give us news too
Old May 21st 2012, 12:41
hotsauce's Avatar
hotsauce hotsauce is offline
Beautiful lowlight. I was contemplating subie power for my bus...... but the type IV won out.
just another square saltine.
www.garagejunkieapparel.com
Old May 21st 2012, 12:47
Originally Posted by rennsport View Post
Hi Rich
give us news too
I would but very little progress lately due to a string of useless trimmers! I have to find number 3 now...
Old May 21st 2012, 16:12
SportyBug SportyBug is offline
Beautiful bus and it sounds great too. I would like to know more about your wheel spacers. I have been thinking of running 5x112 Subaru wheels as well. Do you have any advice or feel that the spacers are not safe?
Old May 21st 2012, 17:18
the subaru wheels are not in 5 x112 , I have 10mm adapter on the front and 15mm on the rear, no probleme for the moment...
I ll more safe if I have porsche wheels !!!, but BBS LM in 17" have 10mm offset
not good for my bus, and I didn t want to fit 18" wheel, perhaps a set of RH turbo twist in 17 ...
