#16
![]() ![]() chassis fitting everything one last time before cleaning painting and last time placing... |
#17
![]() this was our bug in 2019, with the 1641cc engine ![]() this was 2021 but still some struggles withe the 901 gearbox and the 2.8 type 4 combination ![]() and this was this year on Clastres, finally without mechanic problems Last edited by josvandegalaxy; August 16th 2023 at 13:39. |
#18
What struggles were you having with that 901 gearbox?
#19
What's the fuel capacity of this tank?
How much taller than standard is this tank? |
#20
Great update! Tell us more about the 2,8 ltr Type4 pls :-)
#21
the problems with the gearbox, it wasn't only the gearbox, it was the gearbox and the combination of the used parts. - The 215mm flywheel dindn't have the bearing, so we got the flywheel machined and that was a problem solved - once the gearbox became hot, there was an oil leak. the modified nose (also previous owner) was leaking, and you don't want that on a racetrack, so we bought another nose, had to modify it a bit. another problem solved (we tought). But apparently the gears were damaged by the heat. So, another gearbox, the case from a 914 is the same, so... But we forget to change the breather hole (stupid, I know) so once you drive a few minutes in high revs, he throws out the oil. But for now it runs great. Maybe we'll be at Le Bug Show next weekend Last edited by josvandegalaxy; August 16th 2023 at 13:38. |
#22
82mm stoke Scat crankshaft met 104mm JE pistons and cilinders so a 2782cc to be correct.
billet Thorsten Pieper heads with type1 exhaust ports (CSP python 48mm) 322° camshaft. for now still the standard type4 rockers and 48 idf carbs. good for 207 bhp and 280 Nm on the wheels. |
| Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
