#16
By the way, are the rear spring plate replacements necessary on street car for the weight/load transfer to the torsion housing instead of mounting points or is that just crap? Thanks. Sprint. |
#17
IMO I feel they would be necessary, race or street. The weight transfer will be there regardless. But then again, what's different than having the torsion bars there or not. Something to be researched more. As far as toe adjustment,t hey wouldn't adjust your toe at all. Also, why would you want to adjust toe on the rear of the car? Adjusting the toe-in or -out is done on the front tires. Toe-in is safer and more stable, as toe-out will allow you to "turn in" quicker into the turns. A slight toe-out can be used on the street, but your car could possibly be less stable at higher speeds and will increase tire wear.
Julian '74 Super "If you are under control you're going too slow" - Parnelli Jones Last edited by lightning bug; March 15th 2003 at 00:09. |
#18
Sprint. |
#19
Right. When you unbolt the 3 bolts on the springplate, you can adjust the toe. What I meant was that I don't see how the Eagle plates would be different than the stock. Shouldn't have said at all. My bad. Sure you need to for alignment purposes. I thought we were talking for performance reasons to adjust the rear toe. Bad choice of words on my part. I'll shut up now.
Julian '74 Super "If you are under control you're going too slow" - Parnelli Jones |
#20
