Old April 3rd 2003, 13:41
randyj randyj is offline
Thumbs up
Shadowbug,
Nice car!
What size wheels are you running and what disk calipers are you using?
How much did it cost to have your Porsche seats recovered and what did you have to do to fit them in?
Randy
Old April 3rd 2003, 13:58
Shadowbug's Avatar
easy questions to answer
wheels are 15" phonedials, running 195 50's on the front and 195-60's on the back
brakes, 944 brakes front and rear (calipers disc's and rotors)
911 seats, cost $900 canadian to have them recovered with the backseat covered to match, and they adapted quite easily
the tracks of the 911 seats are identical widthe to the stock beetle tracks, but the seats are a bit lower
so i built a H out of 1x2 tubing tacked the 911 tracks to it, removed 4 machine screws to remove the seats, finished the weld, then welded the H to the stock beetle seat rails. Viola porsche seats with theporsche seat adjustment.
(I'm using a '71 pan)
If A guy wanted the seats lower, you could weld the porsch tracks directly to the VW tracks.
Old April 11th 2003, 19:33
mabus013 mabus013 is offline
What kind of five speed did you use, and what did you have to mod to make it work? I've been wondering about that... I'm thinking it's either a vanagon 5spd, a reversed 914, or a 911. Am I even close?
-<M13>-
Old April 12th 2003, 11:21
Shadowbug's Avatar
I used a 901 from a 911
fit was fairly easy, but I had the body off the pan at the time.
Old April 12th 2003, 20:52
darren's Avatar
darren darren is offline
Shadowbugs question time....
what carb linkage are you using?
Is it a straight bar type?
Ta!
darren
Old April 12th 2003, 21:21
Shadowbug's Avatar
its a crappy one that came with the carbs, I had to modify it a bit for it to work with the 911 shroud. Yes it is a strait bar type.
Old April 13th 2003, 21:22
Rob's Avatar
Rob Rob is offline
Very nice ride !!
Since we're asking questions :
How about the firewall ? Is the original still in place or did you cut it out ?
How did you form the aluminum for the firewall ?
Rob.
Old April 14th 2003, 12:40
Shadowbug's Avatar
the original firewall is still in place, I just screwed brushed stainless panels to it.
stainless panels are simple to do, I just used a piece of cardboard and cut it toshape to create a template, then had stainless cut at a local sheet stock reseller.
any trimming I did with a plasmacutter and grinder. touched it up with a flapwheel..
