Old April 9th 2003, 05:20
SprintStar's Avatar
SprintStar SprintStar is offline
Anyone has tried this?
Sprint.
Old April 10th 2003, 15:49
MattKab's Avatar
MattKab MattKab is offline
Post
I wouldn't mess with the ends of the cables. Unless you now the correct crimp pressure and radius. I simply tried what I read on here last year, 'shouldered M4 buttonhead screw and nylock nut aside a new stock '03 cable/1mm washer/stock 944 brake shoe spreader. Slack enough so the cable dosen't have to bend.
The guide tube on the caliper mount needed shortening by ~15mm and 3 layers of heat shrink tubing make a nice strong, straight, sealed outer-cable splice. Cable outer's are 10mm zip tied to the arms. Simple, cheap and very reliable.
The 2 M4 screws I used could together, carry the weight of the car.
The effect of the ~6mm misalignment is negligible. After 14 months daily use, all is sweet. I may yet modify the spreader like in the gallery, tho' it doesn't give me any real concern's.
Matt
Old April 10th 2003, 20:27
SprintStar's Avatar
Good job!!!!
Sprint.
Old April 12th 2003, 15:57
Jim Andritsakos's Avatar
My "moto" is avoid the hassle and the guesswork where you can.
Buy beetle to 944 e-brake cable adapters and that's it.
www.kerscher.de (official site in German)
www.germancarcompany.com (official reseller in UK)
Jim Andritsakos
74 1303 GL (project)
89 T3 Syncro panel
