Old December 26th 2003, 22:31
i got a few small things done. finally got the hood back open. finished some carpetting. did some prep work needed to finish installing my door window seals. then realized the drill batteries could use a refresh. got company and stopped there. too damn cold now. back at it Sunday.
Old December 28th 2003, 23:22
yellow73's Avatar
yellow73 yellow73 is offline
Zen,
It is awful when you have company come over and all they do is talk and not help........it was good to see you on Friday and your house is cool but not as cool as your car.
Old December 28th 2003, 23:39
Thank got I have a mig welder.
Finally got the exhaust on yesterday. Took it back to the shop that bent it for me Friday, then it was too long. So they sliced it and expanded one end so they would slide together. I put the whole thing together, aligned it all, then welded the pipe back together.
Installed and wired the alt and fan, and the fan shroud, then proceeded to strip the shaft for the alt while installing the fan belt, nice thing to screw up a $250 alt. Have to swap out the old one tomorrow.
It's 5 steps from completion. I'm shooting for Wed if I can get the engine tin stripped and painted.
63 356b time capsule
948 project
Old December 29th 2003, 10:15
i know you have to be looking forward to that john. that is cool.
speaking of this...
. i have that back suspension ready to come out. just have to remove axles, spring plates and trailing arm mount. then will start fitting the new one. looking to put my cup brace in at the same time. hence the welding comment. if you still feel like a road trip let me know. i am working on it through the month and will probably take a week off late Jan early Feb to finish this thing up.
dave, oil cooler is going to have to move.
Old December 29th 2003, 10:52
We can move it or fab new plates(shock tower) to mount the brace or both. With that big shoe-horn and some grease, we WILL get it in.
