Old July 10th 2004, 20:24
Originally Posted by NO_H2O
The back end of a Super is the same as a Standard.
Back to the drawing board.
I just don't understand why they are shorter than the ones I took off the car.
line removed = 245mm
correct line ordered = 235mm... 1969 and later IRS
line received = 230mm...
Old July 11th 2004, 18:29
yetibone's Avatar
yetibone yetibone is offline
Wait, your'e using aluminum rear arms, right? Would those nessesatate longer brake hoses from a 951?
Are 951 brake hoses any longer than VW?
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 11th 2004, 21:45
The tab on the arm where the metal line from the caliper connects to the rubber line is in the same location as the VW arms. If I place my old lines on the car they fit but they are in need of replacement. But still why the length difference for the same part...
The 951/944 braided lines I have are too long for the car. Something like 15" to 19" appox...
Old July 12th 2004, 00:16
Anyone know where I can get 13" M/F stainless steel brake lines for my car. My stock 15" lines are too long since I did the disc brake conversion.???
Old July 12th 2004, 14:45
Slopel Slopel is offline
Boygenius, I am doing the same mastercylinder upgrade and I would like to know how much you had to cut down the rod to get the mastercylinder to fit. Is it the threaded unit that hooks up to the brake pedal or the piece that comes out of the mastercylinder? Could you post a pick of this modification?
Thanks.... -Slopel-
Old July 12th 2004, 19:05
I first measured the angle of my pedals with the stock push rod and stock M/C in place. I then installed the 911 M/C and the pedal assembly without the push rod. I placed the push rod into the M/C and next its mount on the brake pedal. I then looked at the difference in length and started trimming down the push rod. If you M/C has the same long collar coming out the back of it you will have to reim that down so it won't stick into the car and possibly bind on the push rod. I ended up with a length of 80mm total measured from end to end including the threads. I used a hand file to round off the end of the push rod just like the factory one. Remember to leave a little extra for mistakes.
