Old October 8th 2002, 15:21
Question FAT Shroud
According to these pics the FAT shroud does fit with some modification to the late style decklid.
This is going to be my goal.....911 cooling for my 914 2.0 with no mods to the case.... instead of the 'bubble' I'm going to cut the decklid for clearance and then raise the licence plate.
Old October 8th 2002, 15:28
Alex's Avatar
Alex Alex is offline
Ehhh...that pic is an early style decklid (W decklid). I am not sure on how many Oval and Split guys would be willing to do this to their rare rear decklids. The later style decklids...on a Super for example....curve out a lot more. That is why the cut is a lot smaller and you can hide it easier. Also the license plate light is a lot bigger and hides more.
Old October 8th 2002, 20:22
oval55 oval55 is offline
Wow, teh left rear wheel is off the ground. he must be coming out of one serious corner with ample speed. That car is very impressive, Is that the look your going for Sandeep?
Old October 9th 2002, 02:12
Alfito's Avatar
Alfito Alfito is offline
Smile FAT Shroud
Hey Sandeep, is it posible that you can post a scanned image about this? I am planning to make the same cut but I do not know how it is going to look. Decklid is the later one.
I've got an issue of Volksworld (Mar 99) with a blue GL with a twin turbo 1.8L type 4. If you look at the rear decklid, you can see a half moon slot cut out...its tough to see because he moved his licence plate up to cover it...but its there.
Old October 9th 2002, 09:00
Thumbs up
Alfito,
I will scan it in this weekend. Are you using the FAT shroud on a T4 ?
Old October 10th 2002, 21:09
Alfito's Avatar
Not yet, but I will, hopefuly at the end of the year. My target is a 2.7L, type IV, with a 9.0:1 CR. On the other hand my car is a bug model 73, and the decklid is the one with two vents. I want to cut as less as possible, in order to hide the weapon from the crowd.
