Old December 8th 2004, 04:10
Erwinvs Erwinvs is offline
Originally Posted by jc_geddes
I have just made the 2 5mm spacers and inserted them behind the bearing seats. Whne tightened up there is still play, as if the bearings are loose. It appears that the spacers need to be a bit bigger then 5mm, I am going to check today, so will beable to report back.
You are right John.I made them 0,5mm higher en the problem was gone!!
I masured it up and the Hub had to go 11mm up.
Then you can make a bracet for the brakes of 6mm. and bold it on to your spindle!!
Originally Posted by Fred100
but which material usinf for space the bearing ??? aluminium?
I used Iron because of the size of the spacers, There not that big. My meaning was that Aluminuim is too weak for those sizes!!
Greetings
Erwin
'66 Splitbus with double slidingdoor
Old December 10th 2004, 08:24
Michael Ghia's Avatar
1mm!
Any update on these conversions?
Sorry if I got it wrong with the bearing spacing difference... whats 1mm between friends
Seriously though... good work..
MG
Old December 10th 2004, 09:23
MG
It could be a difference between the wheel on properly or lossing the wheel on the highway
Hope to post pictures next week on how i dit it.
Greetings
Erwin
